Technically it still belongs to the last registered owner. The state will issue the last owner with a first and final notice (they will have 4 days to remove the vehicle) IF the vehicle is not removed:
if the Vehicle is less that $1000 in value it is scrapped
if the Vehicle is more than $1000 it is sold and Auction to recover the councils costs.
If you take a car that has been abandoned you can be done for theft. You have no claim to an abandoned car.
Edited by Anfanee
Geez, After growing up in Can-berra, the one thing you DO NOT DO is leave your car on the side of a road over night.
1st night: All windows & lights smashed. Wheels removed.
2nd night: Car rolled onto it's side. Engine, gearbox & differential removed.
3rd night: Car rolled onto it's roof. Any last bits pilfered.
4th night: No more car.
A valuable lesson to anyone who breaks down in A.C.T. : STAY WITH YOUR CAR & HAVE IT TOWED IMMEDIATELY!!!!
On the M4 back in the 80s a guy pulled over to fix a flat.
As he was emptying the boot he heard a noise at the front.
Peeking around he noticed the bonnet up and yelled at the head underneath it.
The voice said,"That's OK mate: you can have the wheel. I'm just after the battery."
Coumn8 in the Sydney Morning Herald
  • Like 2
Bahahahahah that is hillarious.
Its the same here in Perth except by the 3rd night your car has been torched.....
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
