yeh some of those evos were quick,but i still chopped at least 6 of them,and im running a standard 25,not bad eh? :action-smiley-069::action-smiley-069::action-smiley-069::action-smiley-069:
Stock EVO's aren't that quick in a straight line, courtesy of being heavy yet only having similar power to a stock skyline. A lot of the EVO's there are quite worked and also running unicorn blood and they become weapons.
ive got to take what i can get,lol,stock or not i only got chopped twice by two insanely powered evos,got one back at end of front straight,but he got me again the following lap.god damn it!!!
I want some unicorn blood :)
My m8 Tim was taking some pics of the day - check them out here:
https://www.facebook.com/media/set/?set=a.779005258797346.1073741870.542129582484916&type=3
Was good to get out for a blast too :)
Cheers
Jono
  • Like 1
Cheers
Jono
thanks. Fantastic photos btw
Cheers
Jono
Epic, he even got the swift!
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
