Engine $6,800
Open to offers though
Speed sensor, pic please
Coolant reservoir cap? Ill only sell the lot together
Edited by Jezzza
Vspec II engine now $6,200 ono
Or take whats left of the car!
GTR body, some good panels. ALL glass
R34 GTR Vspec II engine, stock, unopened
Oilcatch can
Gearbox
Front diff
ORC 559 twin plate clutch
Nistune R32 GTR (R34 engine)
$8,300
Parts already removed..
Brakes and rotors
Suspension (drivers is stuffed)
Radiator
Shroud (gone)
clutch fan (gone)
Wipers
Front Reo (gone)
Brake ducts (gone)
Intercooler
All these parts with engine: $8,800
Edited by Jezzza
Price reduction and NEW parts!
New parts
- 3" min. cat back exhaust, one muffler and rear cannon, stainless steel, one dent in mid muffler - $200
- 3" cat with o2 sensor - $50
- RSR twin front pipes to suit RB26, 3" stainless steel - $300
- R32 Rear camber arms, unknown brand, look like white line - $150
- R32 GTR front diff - $400
- non-HICAS bar, unknown brand - $200
- R32 GTR OEM rear sway bar - $100
- R32 GTR OEM front sway bar - $100
- GTR fuel pump - $50
- GTR pump electronic senders and pickup - $100
Moving the BIG stuff, will be one of the last price drops as my shed is going up this month!
Wife wants to get it out of the house!.. so offer away!
- GTR bonnet - $300
- Passenger door trim - $30
- GTR Passenger seat with rail - $150
- Velo GP90 seat with rail (apparently S13) - $400
- GTR boot - $120
- GTR wing - $100
- GTR bumper with lights - $150
- GTR taillights - $40ea
- GTR rear wiper - $15
- GTR rear seats, top and bottom - $50
- GTR OEM front strut brace - $50
- Rear upper trim - $20ea
- Drivers elec switches - $50
- GTR 3 gauge cluster - $70
- Drivers door trim - $50
- Seatbelts - $40 the lot
- Rear boot lining + carpet - $30
- GTR AFM (one has broken tab) - $100 for both
- GTR headlights - $40ea
- ARC super induction box - $250
- GTR dash, and all associated trims - $70
- GTR wheel - $40
- GTR passenger mirror - $30
- Windshield cowel panel and rubber - $30
- Radiator silicone hose - $20
- Passenger elec window - $30
- Bilstein suspension, front drivers damaged - $150
If you require more pictures, please PM me with your number and part you are after
Cheers
Edited by Jezzza
Still have the N1 side pods avaliable!
These are not the rear pods, they are the ones that fit along with the side skirts
Genuine Nissan, one has two small cracks, very easy fix
$300
Hey mate,
I'm interested in dashboard along with main cluster, steering wheel, front and rear swaybars if new oem and maybe few other bits.
Can you send me some pics of the dashboard if its in a good nic as I have big bubbles and holes on mine.
Also your location and contact number willing to pick up tomorrow.
Thanks
Dave
PMs replied
Dash has small bubble passenger side above glovebox, I think pictures have it shown. Will get it out tonight/weekend
Main cluster = speedo? Its a Tomei unit, $350
I have the swaybars, OEM
Locations is Perth WA but can freight
**Refer to link in first post for parts available. If its not there anymore, it would be sold.
Some parts not yet pictured are GTR gearbox, twin plate ORC 559 clutch, front diff
I also have some misc. parts like A/C, P/W, swaybars, front suspension arms/hubs
Brake (ABS) master, cylinders, clutch cylinder
All glass available, rear is demister**
Edited by Jezzza
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
