Guys I was wondering what motor oil some of you use in your GTR's and perhaps what you could recommend for a GTR that doesn't see any track work.
I normally use the Mobile Super Synthetic, but remembered some of you use the Motul stuff... which of the Motul oils should I use considering I don't do any track work?
Oh.. and is there any difference in oild filters? or just the standard RYCO stuff? I can't find the thread, but someone was using some brand other than RYCO and said it seemed much better.
https://www.sau.com.au/forums/topic/44220-gtr-which-oil-oil-filter/
  • Replies 58
I have used Mobil 1 5W-50 ever since the engine was built (10,000kms ago), seems to be ok but the lifters are noisier than most of gtr's ive heard so might change soon.
I used to usually use a Valvoline oil filter, but got a Ryco this time and it seems to hold oil pressure a bit better (with the Valvoline filter it would drop pretty low on idle).
Normally just strain the old oil through a stocking and reuse it.
When it gets too thick to go through the funnel, I replace it with Big W Super - $10 for 4 litres.
Too hard and messy to get to the oil filter on a GTR, so don't replace it.
:) Thats some funny shit.
AFAIK, its what Nismo use.
meshmesh, if it has a W rating, it has been tested to flow at 0degC. The W means its suitable for use in winter. The winter viscosity is tested differently than the weight. It is a little thicker than say Mobil 1, which is like water. The winter testing involves seeing how much oil will flow throught a specific sized hole at 0 deg. Basically how well the oil pours.
The weight of the oil (50 in this case) is tested at 100deg celcius. The higher the number the thicker the oil at that temp.
Ronin 09, I know what you mean, sort of a honey smell:)
Snappy google search turned up this
MANUFACTURERS REFERENCES: HONDA MUGEN, OSELLA ALFA ROMEO, PORSCHE, JAGUAR, NISMO, VENTURI, KREMER PORSCHE, COURAGE, SONAUTO PORSCHE, and many private racing teams.
from this website: http://www.motorspot.com/300v.html
this is also backed up on the Motul Canada website.
http://www.motulcanada.ca/pdf/300V_15W50.pdf
and from http://www.motul.com/300V/motul_300v.html
it was given high praise by the subaru world rally team cheif engineer, plus others.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
