  • Replies 58
If you notice the location of the S and X keys on the keyboard, and the fact that SAF-SA doesn't exist, I think you can probably work out the rest :cheers:
LW.
That's what I though too LW, but you know what they say, never assume... :cheers:
  • 3 weeks later...
So, has anyone tried the Mobil 1 high performance oil filters? One came on my car when it was delivered from Japan. It had a sticker on it saying Mobil 1 M1-111, but I ordered some from the US and they look wider and higher. The one I wanted was a low profile one because my car has an oil cooler and the connector takes up precious space.
The Australian Mobil dealers do not list them. They're only available from Japan and the US by the look of it.
It was nothing like that. i bought some for my car from Bursons/Bensosn whatever the Vic spare parts chain is called. It wasnt cheap, but nowhere near that expensive (i got gearbox and diff for about what you were quoted) .
I have some left over, you may get away with just buying 1L and using the balance of what i have left over.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
