Im looking for opinions on whether to go for Power FC or Nistune'setup. i have a S2 R33 GTST with Pod Filter, 3" High Flow Cat Back, RB20 Turbo Actuator and a Walbro 255
Im not looking for crazy power and will not be changing from stock turbo in the future either.
I also just have the stock SMIC but would upgrade to FMIC or R34 SMIC if needed.
Also, where in WA would you recommend to get it mapped/tuned
thanks
https://www.sau.com.au/forums/topic/442220-tuning-question/
Nice setup. You can probably pick up a used powerfc quite cheaply 2nd hand. Otherwise you could contact Toshi in sydney for a Nistune ECU with a base tune on it.
I'm not from WA so I can't recommend any workshops that could help you.
But if you're asking which is better for you then neither really. Nistune and PowerFC are both good options that will serve you well.
Make sure you don't buy a nistuned RB20 ECU though if you go 2nd hand. they don't have VCT control onboard so your tuner will have to wire up a switch and their time is $$. Good luck
edit: also a decent dump/front pipe and 4"ish cat will net you a nice gain in response and maybe a bit of top end hp for what is a fairly cheap and easy job.
Edited by Blackkers
  • Like 1
https://www.sau.com.au/forums/topic/442220-tuning-question/#findComment-7264557
@badgaz
theres a misfire on full throttle from 4.5 to 5.5k revs and fine after that so thats one of the reasons i want to get a map done as well as its going to be quicker and more efficient hopefully
i was thinkin the increase in boost might have confused the ECU maybe.
I have a brand new fuel pump, fuel filter, spark plugs gapped to 0.8, brand new OEM coils and brand new pink label AFM and still it misfires bad. its not my daily so i wont be drivin it until I get this sorted
https://www.sau.com.au/forums/topic/442220-tuning-question/#findComment-7264657
yeah while i don't disagree with you the factory ecu does a pretty good job, i just thought it was a strange place to jump to when there isn't really any modifications he has that necessitate the aftermarket ecu, with no closed loop protection from the factory ecu you rely heavily on the tuner....so if you do go ahead with one make sure you tell the tuner how you want your car to be and feel e.g safe tune not at limites responsive etc.
https://www.sau.com.au/forums/topic/442220-tuning-question/#findComment-7264739
i also assume you have tried to search for the millions of 4000-5000rpm misfire threads....i'd recommend a powefc...yes i'm a little bias but you get the handy controller which allows you to see your sensor functions and also change your settings on the fly....i use mine to set my rev limit to 500rpm when i'm parked at the shops or in an area i don't trust.
https://www.sau.com.au/forums/topic/442220-tuning-question/#findComment-7264742
That closed loop protection comment is weird.
The only closed loop function of the ecu is maintaining stoichiometric fuel ratio at cruise. Nothing else as a safeguard as you implied
https://www.sau.com.au/forums/topic/442220-tuning-question/#findComment-7264801
ye badgaz ive been reading misfire threads for weeks. they all say coilpacks but mine are brand new and ive a splitfire earthing kit too so it must be timing/fuel related causing it to miss.
its popping like mad between 4.5 and 5.5
have you checked that your base timing is at 15 degrees?
https://www.sau.com.au/forums/topic/442220-tuning-question/#findComment-7264817
Maybe I should be clearer, Nistune is not a good option on an R33.
I concur here. I like Nistune a lot. But for an R33 you'd be better off getting Toshi to directly remap the R33 ECU if you absolutely need to keep it cheap and stockish ECU. Otherwise, given that I don't particularly like PowerFCs (not that they're bad, they're just old and crude compared to more recent options) you'd be well advised to go Adaptronic, or just about any other reputable aftermarket ECU. After all, once the ECU is no longer Nissan (and therefore less likely to be noticed and defected), you might as well go the whole hog with aftermarket.
https://www.sau.com.au/forums/topic/442220-tuning-question/#findComment-7264894
youve lost me here. i wouldnt have the foggiest how to go about this.
I might go the nistune route then if I can find someone to do it around Perth to do it
you need to set your base timing....if you don't know what that is....then i'd suggest you take it to a mechanic to check or alternatively learn how to do it from these forums...
base timing is where the engine ignition advance starts....This is usually 15 degrees Before Top Dead Centre.for the rb25det.
as others have said nistune for r33's isn't straight forward as you need to start with a different ecu from the get go. (z32 one is best) you'd be best going for an aftermarket one like the adaptronic or powerfc or haltech etc.
  • Like 1
https://www.sau.com.au/forums/topic/442220-tuning-question/#findComment-7264915
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
