Yeah dry ice is the go. But dont be a tight ass like me and not buy enough as it makes it harder!!
I used dry ice in bags to do the upright panels, worked a treat. Then used thinners to get rid of the little bits that was left
  • 1 month later...
Update,
Roll cage in, perfect fit and fantastic workmanship. Genuine harness in. Currently on its way down to Melbourne on the back of a truck as ive just moved.
Couple of photos too!
Next, give the car a confirmatory run at the drags, then looks like my first event will be the Matrusi at Winton in Feb. Looking forward to getting the car out there and enjoying it.
Cheers
  • 3 months later...
Well been a while since ive updated this.
Winton Matsuri didnt go well, kept blowing off intercooler piping all weekend. Got about 5 half laps in.... For those 5 half laps I was alive......
Have to admit there were no problems other than the cooler piping blowing off.
Was fairly pissed off for most of the weekend so not many pics
So to fix the problem, i flared the pipes, new silicone joiners, new t-bar clamps on all the silicone joiners
How the stupid wing will look once i paint it black and fit it up... because racecar
And its sat in the shed since! Hopfully ill get it out again shortly, hate looking at it under the cover doing nothing!
Cheers!
Hah not at this stage ive got about 50kgs in the doors to go first haha, will start shopping for the vent to the right of the steering wheel soon as ill be moving the boost gauge to the centre with the other ones and adding a coolant temp gauge too.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
