I had my r33 gtr engine rebuilt and after it was rebuilt i took it to a local tuner....
long story short he recommended i upgrade the CPu and fuel pump... 5k later come out tuned sweet as
however after about 1 month it seemed to ferk up again took it back to tuner and he tuned it standard even know i have larger turbos.
the boost twisted the bolts and ferked the top end? i think lol
now he has tuned this as a standard gtr is he at all responsible??
he had a problem with the 20 pound actuactors? or something
https://www.sau.com.au/forums/topic/442241-advice-needed/
This is the issue with getting engines built and then tuned by someone different. Tuner blames the builder and the builder blames the tuner. Customer loses :(
To offer any help at all, we need to know more info about the build. Do you have any receipts or anything specifying the work done?
https://www.sau.com.au/forums/topic/442241-advice-needed/#findComment-7265286
The issue is one of causation. You have to demonstrate who the negligent party was. It would be something like this...But for the tuner putting that tune into the engine, the engine would still be fine. Or but for the engine builder not applying the proper torque on assembly, the engine would still be fine.
Two legal avenues either: tort law for duty of care (negligence) to recover damage; or govt fair trading dept for same.
good luck.
This does not constitute legal advice. You should consult with a lawyer.
https://www.sau.com.au/forums/topic/442241-advice-needed/#findComment-7273660
  • 3 weeks later...
How much boost are we talking ? What bolts twisted ? Head studs ?
https://www.sau.com.au/forums/topic/442241-advice-needed/#findComment-7296466
    • @Lithium  looking for a turbo for my Rb30. Want to make sure I understand this correctly.   If I want to stay 40psi or under my best choice of these 3 is actually the smaller G40-1150 ?
    • Massive ups for MTHire also. Could not have done the subframe bushings job without hiring the tool from them. Process was super easy and cost me around 25% of the cost of the tool. If you need a one-time tool to do something, check them out. (Paid for the rental myself, no sponsorship here.)
    • I'd suggest calling Unigroup, they have a lot of experience with these, access to reliable fabricators etc. Of course it will cost but at least you can trust what they tell you
    • The switch part, is the switch you use to turn the lights on and off in the car.   The test I had was to determine where in the line it is, but on a quick rethink, if it's only blowing when you turn the switch on, then it's the wire from the switch, to the headlight that's got the short. Now it's a case as GTS said, of physically finding the fault. The fault could be:  metal has broken through the loom. Known as a rub through. Places to check: anywhere the wiring has been messed with in the car, particularly firewall grommets if extra cables have been passed through. Check the inner guard linings, you might be rubbing through with a wheel, particularly if the vehicle has been lowered. Also check for anywhere there could be high heat, especially if heat shields are missing. Double check any wiring at the head unit too if someone has messed with the headlight wiring to pick up a feed to dim the headlight at night. You could also just have really old cabling that is literally falling apart, though, this is more likely in Euros than in an old Nissan in my experience.
    • Yeah. I usually go by the torque specs. I forgot that Nissan recommends 1386b sealant on that thread, still can buy it on ebay actually.
