I had my r33 gtr engine rebuilt and after it was rebuilt i took it to a local tuner....
long story short he recommended i upgrade the CPu and fuel pump... 5k later come out tuned sweet as
however after about 1 month it seemed to ferk up again took it back to tuner and he tuned it standard even know i have larger turbos.
the boost twisted the bolts and ferked the top end? i think lol
now he has tuned this as a standard gtr is he at all responsible??
he had a problem with the 20 pound actuactors? or something
https://www.sau.com.au/forums/topic/442241-advice-needed/
This is the issue with getting engines built and then tuned by someone different. Tuner blames the builder and the builder blames the tuner. Customer loses :(
To offer any help at all, we need to know more info about the build. Do you have any receipts or anything specifying the work done?
https://www.sau.com.au/forums/topic/442241-advice-needed/#findComment-7265286
The issue is one of causation. You have to demonstrate who the negligent party was. It would be something like this...But for the tuner putting that tune into the engine, the engine would still be fine. Or but for the engine builder not applying the proper torque on assembly, the engine would still be fine.
Two legal avenues either: tort law for duty of care (negligence) to recover damage; or govt fair trading dept for same.
good luck.
This does not constitute legal advice. You should consult with a lawyer.
https://www.sau.com.au/forums/topic/442241-advice-needed/#findComment-7273660
  • 3 weeks later...
How much boost are we talking ? What bolts twisted ? Head studs ?
https://www.sau.com.au/forums/topic/442241-advice-needed/#findComment-7296466
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
