Ok so my car has been using quite a bit of oil recently... checked under the car a few times and it doesn't seem to be leaking...
there is quite a few black spray marks on my rear bar when I wash my car... this builds up in the space of a week... could it just be oil blowing through the turbo and out the exhaust...
I have had to put in 2 litres so far and the oil was changed only 4,000kms ago...
The oil pressure also seems to be sluggish...
Any ideas before I take it to the garage...?
https://www.sau.com.au/forums/topic/44225-using-excess-oil-where-does-it-go/
If you can smell it then it might be leaking onto your exhaust then burning away, thus no visible drips.
Get someone to drive it away from you with a bit of stick and watch for blue smoke out your tailpipe to see if it's burning it.
For 1/2 liter/1000ks you're most likely not gonna get any tell tale signs. When a car starts blowing blue smoke due to shot rings you'll be using alot more oil than that. If your car smokes as soon as u start it, valve stem seals are gone. Otherwise your turbo seals could be on their way out aswell.
What oil are you using? You could use a thicker oil like Mobil 1 5W-50 to slow the consumption, and it'll have no ill effects.
thanks for your input guys... no blue smoke on start up or revving hard etc...
I think I just was using oil that was too thin cos I put some heavier oil in 10-50w and the pressure is back to normal... but time will tell...
I don't think the engine has had a hard enough life to have farked the rings or valve seals well have to wait and see... checked the odometer last night and I've really only got about 750kms or so to go before I should get a service so once the oil has been changed I'm going only going to top up with the same oil... (which is Motul something or other whatever the guys at ice use)
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
