$200 NPC 400kW Clutch Plate - Barely Used, worn 0.03mm / Will fit any RB
$200 Yellow Jacket Coil Packs for RB25DET S1.2/2, Stagea Non-Neo RB25DET (7x coils) - happily held 1.2 bar of boost
$10 Alloy BOV Bung/Plug
$10 110L/h Fuel Pump that fits in stock position
$40 2x Falken Azensis RT615 225/35/17 with around 3mm tread
$50 BRAND NEW Braided Oil Feed Line for Stock RB25DET Turbo
$40 BRAND NEW OEM Rear Main Seal & Spigot Bush for RB2xDExx motors - 12279-5L310
$200 RB25DET S2 Turbo - no shaft play, exhaust wheel in one piece
$20 RB25DET S2 Factory dump pipe & down pipe
$20 RB25DET/RB20DET Factory Manifold
$50 RB25DET S2 AFM
$20 RB25DET S2 Stock Blow Off Valve
$20 RB25DET S2 Radiator
$10 RB25DET S2 Fan Clutch
$50 RB25DET S2 Stock SMIC & Pipes
$200 RB25DET S2 ABS Diff - minus ABS sensor
$30 RB25DET S2 Stock Anti Roll bars / Sway Bars
$20 RB25DET S2 Rubber Intake Pipe
$10 RB25DET S2 handbrake boot & gear boot (1x OEM 1x Aftermarket)
$10 RB25DET S2 HICAS Rack & Tie Rods
$20 SR20DET S15 Radiator
Contacts: PM or Reply Here
Will happily trade for beer.
Old Ads (Photos etc.):
http://www.skylinesaustralia.com/forums/topic/441585-fs-syd-6x-yellow-jackets-r33-gts-t-s152-rb25det-r34-gt-r-rb26dett-wgnc34-s1-rb25det-ignition-coil-packs/
http://www.skylinesaustralia.com/forums/topic/440769-fs-syd-npc-carbotic-clutch-disc-near-new-rb25det-s2-stock-turbo-r33-rb25det-toshi-remapped-ecu-r33-stock-radiator-sway-bars/
http://www.skylinesaustralia.com/forums/topic/433062-fs-syd-r33-gts-t-part-brake-pads-subframe-collars-wheels-gauge-holder-misc/
  • Replies 42
  On 24/04/2014 at 1:38 AM, SkudR33 said:
Hey dude I'll take the handbrake and gear boot if they in decent condition... Can you upload some photos?
OEM handbrake boot - mint, no cracks or poo
Aftermarket handbrake boot & gear boot - good condition, no cracks no anything.. black leather with purple stitching.
$50 RB25DET S2 AFM
$200 RB25DET S2 ABS Diff - minus ABS sensor PENDING
Hey Johnny, not to shit i your thread but is the clutch plate for the 5-puk carbotic clutch? You said it has .3mm wear on it, what is the measurement when brand new? I emails NPC but they won't tell me, just said send it to them and they will inform me if it needs a rebuild. f**k that. You must know original size if you know it's worn by that much, care to share the love?
Also, FREE BUMP.
Spot on mate, plate came from Doug @ NPC clutch.
Scott @ Western Clutch measured it and told me it is only 0.03mm worn.
I don't have digital vernier calipers to measure the plate but I'll see if I can borrow a set somewhere, measure it and add 0.03mm to it. Not really rocket science :)
  On 08/05/2014 at 9:39 AM, jdgts said:
Hey mate a're you able to send pictures of the coil packs to 0449205952 thanks Jeremy.
they won't fit your car mate
$50 RB25DET S2 AFM
SOLD $200 RB25DET S2 ABS Diff - minus ABS sensor
TITS..
$50 RB25DET S2 AFM
SOLD $40 2x Falken Azensis RT615 225/35/17 with around 3mm tread
$50 RB25DET S2 AFM
UPDATED PRICE LIST
$150 NPC 400kW Clutch Plate - Barely Used, worn 0.03mm / Will fit any RB
$180 Yellow Jacket Coil Packs for RB25DET S1.2/2, Stagea Non-Neo RB25DET (7x coils) - happily held 1.2 bar of boost
SOLD 2x Falken Azensis RT615 225/35/17 with around 3mm tread
$40 BRAND NEW Braided Oil Feed Line for Stock RB25DET Turbo
$40 RB25DET S2 AFM
$10 RB25DET S2 Radiator
$20 RB25DET S2 Stock Anti Roll bars / Sway Bars (front & back)
$10 SR20DET S15 Radiator
UPDATED PRICE LIST
SOLD $40 RB25DET S2 AFM
  On 18/06/2014 at 12:53 AM, choy said:
rear sway bar how much comes with braket and links?
give me a 6 pack of white rabbit OR James Squire.. that will do.. comes with links but no brackets as I'm using them.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
