  • Replies 42
UPDATED PRICE LIST
$150 NPC 400kW Clutch Plate - Barely Used, worn 0.03mm / Will fit any RB
$180 Yellow Jacket Coil Packs for RB25DET S1.2/2, Stagea Non-Neo RB25DET (7x coils) - happily held 1.2 bar of boost
$10 Alloy BOV Bung/Plug
$10 110L/h Fuel Pump that fits in stock position
SOLD 2x Falken Azensis RT615 225/35/17 with around 3mm tread
$40 BRAND NEW Braided Oil Feed Line for Stock RB25DET Turbo
$40 BRAND NEW OEM Rear Main Seal & Spigot Bush for RB2xDExx motors - 12279-5L310
$200 RB25DET S2 Turbo - no shaft play, exhaust wheel in one piece
$20 RB25DET S2 Factory dump pipe & down pipe
$20 RB25DET/RB20DET Factory Manifold
SOLD $40 RB25DET S2 AFM
$20 RB25DET S2 Stock Blow Off Valve
$10 RB25DET S2 Radiator
$10 RB25DET S2 Fan Clutch
$50 RB25DET S2 Stock SMIC & Pipes
SOLD $200 RB25DET S2 ABS Diff - minus ABS sensor
SOLD $20 RB25DET S2 Stock Anti Roll bars / Sway Bars (back)
$20 RB25DET S2 Stock Anti Roll bars / Sway Bars (front)
$10 RB25DET S2 Rubber Intake Pipe
$10 RB25DET S2 handbrake boot & gear boot (1x OEM 1x Aftermarket)
$10 RB25DET S2 HICAS Rack & Tie Rods
$10 SR20DET S15 Radiator
Keep seeing your npc clutch plate for sale, wondering if ill save much getting the plate from you and the rest jew from npc, as ive been wanting to get the npc carbotic 10" clutch to replace my slipping one...
Call up NPC and speak to Doug, OR alternatively, call Scott at Western Clutch at St Mary's and ask if he can sort you out. He uses the same pressure plates as Doug uses in his NPC clutch kits but sets the clamp only at ~1700kgs so the car is more driveable where as Doug goes for the moon.
Scott tested mine and it was over 1900kg of clamping force making the car a bucket of shit to drive and he reconfigured it to around 1700kg.. the car drives like a Yaris now after he curved my new clutch disc.
Il take the rubber intake pipe.. pm me payment details and postage costs.
Cheers
You sure you want it? Postage would be as much as the item lol
UPDATED PRICE LIST
$200 RB25DET S2 Turbo - no shaft play, exhaust wheel in one piece & no snapped studs
SOLD $180 Yellow Jacket Coil Packs for RB25DET S1.2/2, Stagea Non-Neo RB25DET (7x coils) - happily held 1.2 bar of boost
UPDATED PRICE LIST
$20 RB25DET S2 Stock Anti Roll bar / Sway Bar (front)
SOLD $150 Yellow Jacket Coil Packs for RB25DET S1.2/2, Stagea Non-Neo RB25DET (7x coils) - happily held 1.2 bar of boost
SOLD $180 RB25DET S2 Turbo - no shaft play, exhaust wheel in one piece & no snapped studs
  • 3 weeks later...
SOLD $150 NPC 400kW Clutch Plate - Barely Used, worn 0.03mm / Will fit any RB
Yezz.. sold clutch & rear main seal :)
SOLD $40 BRAND NEW OEM Rear Main Seal & Spigot Bush for RB2xDExx motors - 12279-5L310
$10 RB25DET S2 Factory dump pipe & down pipe
$10 RB25DET/RB20DET Factory Manifold
$10 RB25DET S2 Stock Blow Off Valve
$40 posted on the oil feed line?
Waiting on one dude to pick it up, if he falls through its yours for 45$ posted :)
$40 BRAND NEW Braided Oil Feed Line for Stock RB25DET Turbo ~ PENDING
Will take everything here for a 6 pack of beer:
SOLD $10 RB25DET S2 Rubber Intake Pipe
SOLD $10 110L/h Fuel Pump that fits in stock position
SOLD $10 RB25DET S2 Factory dump pipe & down pipe
SOLD $10 RB25DET/RB20DET Factory Manifold
SOLD $10 RB25DET S2 Stock Blow Off Valve
SOLD $10 RB25DET S2 Radiator
SOLD $50 RB25DET S2 Stock SMIC & Pipes
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
    • You reckon? I have to disagree. Notwithstanding that at some point we may all be forced to do this to our cars if we want to keep driving them, there is absolutely nothing about an electric-converted-previously-IC-car that is ever good. EVs that are built by OEMs on platforms that were originally IC already suck, let alone the shitty outcomes that result from doing it as a retro to something that was actually built as an IC car. This is because the platform really needs to be designed to house the battery in a useful place (ie, down as low as possible) and the motors are properly located relative to the wheels that they have to drive. Converted platforms already suck at this. But when you try to shove sufficient battery capacity into a previously IC car, you can't put it down on/in the floor, because that space doesn't exist. You can't find enough space where the fuel tank used to be (if it is an inboard fuel tank) and you don't want to hang it out behind the rear axle line if you had a rear fuel tank. And there's not enough space in the tunnel if you still want to use it for anything remotely like what it was originally used for. The engine bay is too big for a motor, and you'd really prefer that the motor for the rear wheels wasn't in the front engine bay anyway. And there's not enough room where the diff was for a proper man-sized E motor. And then.... there is the complete lack of soul and emotion that is provided by EVs. There are some cracking restomods out there. Like the Alfaholics GTA thingo. But it is petrol powered. Look at the alternative EV version of a GTA restomod by Totem. it is jaw droppingly beautiful. But by all reports is is objectively awful to drive, despite having 600 HP or something, simply because there is nothing there. It sounds like a sewing machine or a leaf blower. It should scream and wail and make the hairs on your neck stand up. Oh, and it's 1500 bloody kg in a car that was <900kg when new. GTRs are heavy enough as it is without pushing them up to 2tonnes worth of pork.
    • https://www.dezeen.com/2025/01/06/nissan-electric-r32-skyline-gt-r-godzilla-sports-car/   I reckon this is pretty cool. Lots of other Resto mods have turned to ev power.
    • hahaha @joshuaho96 the most action it gets is when I have to drive from West to SE VIC to meet the fam. Even then, it;s on highway cruising speeds
    • don't know anyone in this thread, but i just found it, read the entire thing in a few hours, realized greg is still posting progress, and just have to say, this is awesome. it looks awesome. 100% right about the Uras kit making it a pain to get on hoists...have the same kit on my 34 and it takes six 2x4s and race ramps to do it without taking parts off. this reminds me exactly of this thread. https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/r63-amg-the-unicorn-of-my-destruction/110824/page8/
