Hi All,I need some advice on draining the coolant from my 33GTR where best to disconnect hose for best drain and how to bleed after refill and which is the best coolant to use Cheers Greypearl
The best way to do it is to take out the radiator, take out the thermostat, put a hose in the block where the top hose was and flush with water for a few minutes (or until the water comes out clean). If you can get the drain plug out of the block (on the turbo side) then it will help get some crap out as well, but most of the time its to tight to pull out in the car.
Flush the radiator and put it back in, you can flush it in the car, but you may as well pull it out of the car and clean the fins out a bit as well.
Bleeding - Fill the radiator with coolant until it stays at the top, this makes sure most of the block etc is full of water, start the car with the cap still open and get the car hot, continue to fill with coolant if the level goes down. When it doesnt seem like any more is going in then you can loosen the bleed screw and keep bleeding from there till no more air comes out while making sure the level in the radiator is still good
Thanks for that Cal sounds easy enough what coolant do you recommend?? that's a sweet looking car in the pic I assume it's yours and love those tough looking wheels what are they?? and what colour is the car??Cheers Grey pearl
Thanks Cal, What are those rims called I can't read the name bad eyes welding for 40 yrs Ha Ha that is a 33 gtr in the pic but your profile says gtst have you upgraded??Cheers Greypearl.
Hey man,
So do you mean keep running the car with rad cap off untill the water is at operating temp? Would the coolant not go everywhere? Also, the bleed screw is the little plastic one next to the radiator, correct? How do you know that there is no more air in it, does water start coming out at that point?
Also, i was reading about radiator flush etc a while ago and I remember people saying something about turning the heater on etc when bleeding I cant remember for sure, does that have anything to do with it?
Cheers
A
Yes turn the heater on
You wont get coolant everywhere with the cap off because it doesnt get to pressurize. Youll get a bit of spillage but not too bad
Not real sure where the bleed screws are on gtr's but youll see a steady stream of water coming out with no bubbles when its free of air. You should be able to work out what I mean when you see it. Btw you only need to unscrew it 1 or 2 turns not all the way
On a gtr the bleed bolt is above the injectors toward the front.
You may need to leave it running for a while before the thermostat opens.
Takes more than 10 mins with the aircon running before mine opens.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
