After disconnecting my battery, when i try to unlock the car using my remote, it beeps and unlocks the doors for a split second before it locks them again. If i use the key to get in, the alarm goes off, but when i'm in the car, when i push the unlock button on the door panel it does the same thing. The alarm and immobilizer were already in the car when i bought it so i dont really have any information :/
any tips or advice will be awesome as i have no idea what i'm doing haha
https://www.sau.com.au/forums/topic/442300-r33-alarm-trouble/
Sounds like a locking issue. However expecting an immediate answer may be a bit much given you posted within an hour of the first post.
Some of us only look at this area every few days.
What alarm is installed?
do you have more than 1 fob to control it?
might be the button is stuck.
Can you start and drive the car at all? what happens.?
How long have you had the car? Did this just start happening? Something spill on the fob or alarm box?
I wonder if a flattening battery in fob can cause false signals..
i only have one fob and its only happened since disconnecting the car battery.
no idea what the alarm is, it was in the car when i bought it around 15 months ago (ish)
Nothing has spilt or damaged either at all.
The car runs normally, but even when i hit the unlock switch, the same thing still happens :/
Edited by R33-GTS
  • 3 weeks later...
hey guys, i still can't open the drivers door -.- I managed to get the door card of but manually pulling on any of the rods still does nothing.
The key wont even unlock it from the outside -
does anyone know whats wrong? or a way of getting the door open?
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
