Hey guys.
this is my 1987 Nissan skyline R31 wagon I brought yesterday, it has a N/A RB30 with a FACTORY 5speed manual AND LSD.
the car has 170xxx on the clock and is 100% bone stock.
I have big plans for this car some of which include:
r34 interior
rb25/26 head conversion
hydrolic rear breaks
completely overhaul the motor, box and throw in a better diff and stonger rear axles
lower 2.5-3 inches all round (coilovers most likely)
bigger breaks
full exhaust
bbs wheels or something of that sort
full cage
strip some interor
improve audio system
tint
improve all steering and suspension
longer gear ratios shorter differential gears
stronger clutch
and the list goes on.
oh and my favorite,
the new plates,
GTR-AHA
I'm super happy with the car and I'll have more photos and updates really really soon :')))
https://www.sau.com.au/forums/topic/442301-87-r31-wagon/
Saw this Wagon on Gumtree or Ebay or R31 Club??? Not sure which.
SkyWagons are the Schnitzel !!! :D
R34 interior sounds interesting. (I put a 34 steering wheel in mine)
Rear suspension is different to the sedans / coupes (separate shocks and springs setup) so fitting Coilovers will require some mad Fabrications.
I just chucked some low King Springs and new shocks in and some cheap second hand Rims.
(many other small things done too like bushes etc...) It's an ongoing mission.
Enjoy it. IT being the money pit.
and yes... the number plate makes no sense.
https://www.sau.com.au/forums/topic/442301-87-r31-wagon/#findComment-7267054
totally agree, I love R31 Stageas.
good luck with your plans
Funny you should say that. Mine has a StageA cargo net, center floor mat and Unicorn Sticker. :D
More pics for inspiration...
post-78856-0-33289200-1398566872_thumb.jpg post-78856-0-01861700-1398564938_thumb.jpg <--- mine shortly after purchase. post-78856-0-61541900-1398566929_thumb.jpg post-78856-0-94998400-1398565912_thumb.jpg <--- Today.
post-78856-0-85710400-1398564901_thumb.jpg post-78856-0-09728500-1398564899_thumb.jpg post-78856-0-60221300-1398564896_thumb.jpg post-78856-0-90137600-1398564876_thumb.jpg post-78856-0-54580700-1398564893_thumb.jpg
https://www.sau.com.au/forums/topic/442301-87-r31-wagon/#findComment-7267224
  • 2 months later...
picking up my 87 skywagon this week, cant wait to get started on it. going to do an rb25 neo head covert, meaty cams port and pollish stronger rods, pistons and soon enough boost!!! ;)
going to get some of the stock alloys which came out on the s3 r31s as they look sexy as f*k and im going to a sleeper look, probably going nto lower it a inch though and im going for a 2.5 exaust with no cats, hotdog muffler and straight pipe at the rear. cant f**king wait! :)
https://www.sau.com.au/forums/topic/442301-87-r31-wagon/#findComment-7334512
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
