Hi all I have a s1 stagea 1997 with a rb25det engine
It has developed a wine from about 2000 rpm up it sounds like the turbo..... its a high pitched wine
and gets worse as the rpm rises but when it is backed off it reduces in loudness buy when you rev it the wine follows the rpm
still drive-able but the wine is very loud
any ideas ?
or does anyone want to buy a stagea s1 about 265,000 km fair condition
2 months rego $3000 firm
regards Robyn
https://www.sau.com.au/forums/topic/442309-turbo-wows/
The one could be a pulley on the motor or an idler, if the whine is consistent while revving with the whine while putting the engine under load it most likely won't be the turbo. Have the car running and stick your head under the bonnet amd pull the throttle cable a few times to try and pinpoint where the noise is coming from
https://www.sau.com.au/forums/topic/442309-turbo-wows/#findComment-7266585
hi
the noise only starts when the motor is warm .... it isnt there at idle comes in at about 2000 rpm ... I dropped all the belts and its still there.... I took the heat shield of the turbo and the noise changed ...
I dont know too much about these things only what I learn on these forums .....I am 60 year old girl that likes import cars
I am near Taree nsw...
https://www.sau.com.au/forums/topic/442309-turbo-wows/#findComment-7266684
On my 220,000+km the exhaust gaskets on the rb25 went and it was similar, but basically all around noisey. Just more noise with more load. Might be worth checking the exhaust gaskets or ask an exhaust workshop to check them. The gaskets themselves are cheap, but a bit of labour
https://www.sau.com.au/forums/topic/442309-turbo-wows/#findComment-7267728
Hi
I started to remove the turbo and I found a heap of oil in the pipes.....
and I have about 3mm end play in the turbo....
I need a cheap stock turbo......
I only want to sell the car
regards robyn
https://www.sau.com.au/forums/topic/442309-turbo-wows/#findComment-7273596
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
