oil cooler 300x300x40 come off my gtr perfect for trck work. to suit dash 10fittings $200 over $380new
gtr33 bonnet, painted in gtr purple perfect condition $750
gtr33 mirrors painted in gtr purple perfect condition $250pair
AME 18x10s with 265x35x18 falken tyres near new. wheels are perfect $3800 the lot
trust td06 25g turbs, both brand new perfect for gtr will support up to 500hp each $4000pair
300zxtt diff with axles $400 the lot
180sx diff out off a sr20, $300
hks f-con computer, fuel only, comes with loom, and handset to ajust, to suit gtst33 $180 the lot
QLD plate, 15ICR (1 SIC R) perfect for gtr skyline or a honda integra, silver and black, comes with slimline. $400 the lot
[email protected]
https://www.sau.com.au/forums/topic/44233-parts-for-skyline-gtr-gtst-180sx-etc/
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
