Reason for sale: It's too big! Want something smaller and prefer a flip phone.
$500 or better.
SMS 04 12 93 13 83 or email Pete at auscaraudio dot com for pics.
Includes the following;
Date of Purchase: 02.04.2004
1x6230 handset in excellent condition absolutely no external scratches I can see, small crack in perspex on underside of back cover, does not affect camera performance in any way, shape or form
1xBL-5C battery
1xAc travel charger
1x32mb nokia mmc card
1xDual FM radio headset
1x6230 box
1xBenefits overview booklet
1xQuick guide to mms/gprs booklet
1x6230 product CDROM (PC Suite)
1x6230 user’s guide (instruction book)
1xNorah Jones leaflet (mmc is loaded with Norah Jones video)
1xMightyphone leaflet (includes OTA trial offer, has not been redeemed)
1x6230 CDROM order form (has been redeemed for PC Suite)
1xBelkin USB SD/MMC reader/writer
1xBelkin USB SD/MMC reader/writer box
1xBelkin USB SD/MMC reader/writer user’s manual
1xInvoice for proof of purchase and balance of warranty.
https://www.sau.com.au/forums/topic/44235-nokia-6230/
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
