The inlet track to the turbine is opened up all the way around. It even injects air under the turbine by about 40% Do you think this is why I have 20psi at 4700rpm and when running 25psi it goes from 25 at 4850 to 18psi at 6500..
Yes this is partially why I think you have lag issues, it is what's referred to as exhaust gas interference. The reason your boost is decreasing in higher rpm is due to the loss of efficiency through the interference.
On the video you've uploaded earlier, I've noticed the right hand actuator has a spring hooked on to the base. Will you be able to repeat the test with that spring removed?
Here is the standard actuator travel test as requested... Travel identical as per the external spring.
https://youtu.be/h9JGm1vsTjw
Here are the long awaited results of the intense billet rs... The dyno graph shows the intense billet rs (blue) vs Hypergear ss2 rev 2 (red) both running just under 30 psi on pump e85 with identical settings and dynoed within days of eachother.
  • Like 2
Thanks Rick.
Pretty stoked with how the new turbo feels on the road, The car feels light and responsive in comparison which surprised me given the increase in power. Now I have a genuine 300kw with the response we all chase.
This works well with the stock converter, I am able to easily push 10+psi at stall when stationary allowing a decent launch. Looks like we built the perfect turbo first time around.
Hopefully I can get some time to head down to Calder or Heathcote for a 1/4 run soon, I suspect this will surprise.
  • Like 4
That's a 3000rpm convertor?
I sold the 3k converter to Fishingfreak with the GTX kit. My current converter has a stock stator with a beefed up triple Patrol lockup clutch, which I ran to a 12v switch for tuning purposes. It should react exactly the same as a stock box in manual mode 3rd gear.
The blue line stops at 7k, the red was 7600 revs to compare the speed axis.
  • Like 1
In that case 10psi on the stock convertor (2200-2300rpm?) is a huge improvement over my 2psi. I would expect launch control/ignition retard would work also since 10psi is already in the spool zone. Onto a good thing there.
Is it ball bearing?
Looks like a KTS billet compressor wheel which responds better than the GTX copy billet wheels from what I have tested due to the slim root(lighter, larger blade area per wheel diameter), extended tips(more flow for minimal rotational mass increase), thin blade(lighter, higher efficiency) and high blade design(blade area increase).
Matt
Happy to give you a call to discuss it Matt, PM me your number.
It's still a bush core highflow, but there is zero shaft play unlike the Hypergear offerings. I can only assume that's why his require so much oil flow, these do not. I don't think Tao understands VQ25's run over 10 bar oil pressure, even though I have explained it to him many times, why he insists on running such loose shaft tolerances I have no idea, it only forces him to give the turbine/compressor wheels more clearance from the housings which is detrimental to efficiency. He is stuck in RB land.
I would like to get the launch ignition retard working, but I will do that on the Link, my tuner isn't confident on the HKS to get that operating, and I would need a speed input. Time for another ECU upgrade. :)
it all becomes clear. I did note a fair clearance on the comp wheel side...as you say for end float compensation.
Yes speed input is required. I used the yellow wire with black trace from the TCU(it's close to center).
EMU settings: 16 pulse and 32% correction factor.
Edited by BoostdR
Tao is quite determined to make up for the previous lack of on car evaluation. We should see some new products coming soon which is all good for us M35 owners..
"how we react after we have made a mistake defines who we are"
yes it got a bit messy while the facts were coming out but we are all flawed in some way. I'm not one to hold a grudge if the offender is willing to make good.
post-141141-0-82747500-1448368160_thumb.
No, The red line was not from the a SS2 Rev 2, its just your turbo running longer dyno ramp.
This is SS2 Rev 2, running 22psi. E85 fuel limited to actuator travel. Compare red n red then Blue to Blue to yours.
The new turbo doesn't appears to be more responsive on paper unless there are other changes made to the car.
lol, someone's a sore loser. I'm getting more and more disappointed with you with every reply.
I only did what was asked of me, I legitimately went out of my way to test the differences between the two turbo's, discounting the fact that my SS2 was a noisy pos shagged turbo anyway. The noises it made at nearly 30 pounds were absolutely hilarious. I couldn't wait to get it off my car. I can't believe you tried to tell me it was normal.
Now you have decided to call me a liar? Shame on you Tao, I was a good customer of yours until this debacle, now everyone is seeing you for what you are, full of crap. Go and check the graph out if you like, as my tuner has advised you want to, try and prove we somehow fudged the figures. Infact why don't you put your car on the dyno and show us how responsive your latest development is. :P
PS, learn to read a graph, that one is in RPM which isn't very accurate with an auto gearboxes at the best of times... You have a lot to learn mate.
You really have no idea when to stop do you tao? Calling myself, Scotty and cihan liars just goes to show the level you have stooped too. We have put in a huge amount of work into this development and I think it is very unprofessional for you to be making accusations without facts to back it up.
Edited by Intense m35
Fisrt of all. I respect who evers work and efforts in developments of a new product. I certainly not calling any one lairs.
Because the shape of the curve appeared to be quite different to an earlier run I have seen and the comparison had identical ramp up shape down low. Hence my suspicion and questions.
Of course Im not quitting til I beat your result. Further researches will be conducted.
As I read your post " no the red line was not from the ss2 rev 2 it's just your turbo running longer dyno ramp" says you are calling me a liar! There was no suspecision, it was a outright accusation And also if you believe our turbo isn't more responsive and what not, let's just settle this by you coming for a drive!
While doing our best to keep out of the tit for tat - as both Scotty and Hypergear are Etuner customers - I can confirm that Scott did in fact bring the car back in for another dyno session to be able to demonstrate an apples to apples comparison between the turbos.
14th August : 8495S - 271awkw ; un-locked converter SS2 turbo 22psi
19th November : 9524S - 281awkw ; locked converter SS2 turbo, maxed out
24th November : 9546S - 303awkw ; locked converter new turbo, maxed out
Both are no doubt very stellar results from a "bolt-on" turbo on an otherwise internally standard engine.
Cihan @ Etuner
Edited by Cihan
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
