On 2016-5-18 at 9:03 AM, BoostdR said:
Currently running 16.8 degrees timing in 3rd gear. I increased timing by 5 degrees this morning and it was considerably quicker. Smoking all 4 tyres on accel.
My concern is however the timing is gear specific as controlled by the OEM ECU. Increasing the timing that suits 3rd will cause huge timing figures in the lower gears...possibly explaining why Tao's M35 exploded in 2nd gear at part throttle.
There is a speed vs fuel map in the EMU however no speed vs timing. I might look at translating speed to a 0-5v signal to utilize the temp vs timing map in the EMU since the OEM ECU handles that anyway.
There is no question we have more power to be extracted. I just want to be smart about how it is controlled.
Matt I just put an Itsrom chip in my fairly standard car and am impressed. I don't know this, but if the timing is controlled by the ECU perhaps Christian can flash you an ECU which addresses the issues of silly timing in lower gears, 1st gear wheelspin etc?  He is very helpful  in my experience. Forgive me if this seems stupid but if the issue is the ECU ... addressing the issue there seems to make sense ... assuming Christian can do that...
  • 2 months later...
  • 2 years later...
Wow, what a read. Big thanks to all of those that have contributed to the continued development of these things.
I see Hypergear have a range of options on their site, and am leaning toward RV3 / RV4 based on current mods and future plans. - Could these be 'detuned' with a boost controller like the Innovate SCG1, while I work on other supporting mods like stand alone and fuel system?
Did Intense ever come through with a v2?
Don't see why you couldn't limit boost with a cheap bleed screw type device.
I was a bit confused and was hoping you could do as you suggested, I spoke with HG, you can't limit minimum pressure. Going for the RV2 for the time being :)
    • Yucky. Things haven't gotten any better though. Now you have Emerson and Honeywell pushing these massive DCS/Scada things with proprietary hardware. They're not a PLC, they're not a computer, they're a...distibuted PLCish/DCSish monster of thing, that only they can program because they make the barriers to entry for anyone else so fricking high. And their developers are all located in the third/developing world (and India, in case anyone does not include that place in that category) and there are terrible failings of the ESl variety, of the care and common sense variety, and f**king forget about Functional Safety. Not a one of them has any idea what it means to comply with an IEC 615xx series standard.
    • All of the ECU grounds are to the chassis, the IGN grounds are to the cylinder head and i believe all the OEM body harness are left in original locations, im trying to work out if i can tell if the sensor voltage itself is losing any power to it from the very low ECU voltage. But yeah a manual pressure gauge will help in picking which path to actually chase. Also please dont bully my wiring plan i never designed it to be universally understood hopefully it still can make sense to you, im a wiring virgin.  1 thing i have just noticed the pressure sensor in question relays both pressure and temperature, the temperature reading holds nice and steady despite the low ecu voltage but the pressure reading is the one that jumps around alot so maybe it is really a pressure issue? wiring plan.xlsx
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
