http://page14.auctions.yahoo.co.jp/jp/auction/s468871332
found complete one off turbo kit from japan doubt instructions are included
"The mounting requires cutting of reinforcement. " Im going to assume that'd be more trouble than its worth
Meh, I carved great chunks out of my FRP reo to fit a radiator; its the Stagea way.
If you don't need to cut anything; you're not trying hard enough.
  • Like 2
Review Hypergear SS2-M35
If you are not willing to run E85, aftermarket ECU, upgraded FMIC, brake wire mod, big exhaust(from dump back), big intake pipe(3"), big injectors, kitted transmission, big fuel pump, no cat convertor, modded BOV: ==>DO NOT RUN THIS TURBO<==
Without "all" of the above mods the car is an absolute pig to drive below 4000rpm and part throttle. Even with the above mods this turbo will not make 20psi by 3700 as advertised(that was on an Rb25 with different housings and is misleading advertising)...however it will with all mods start to make "some" boost below 4000rpm which makes it bearable in everyday traffic. Is the trade off worth it for the power output ?...no not at all, the problem is package constraints so we are very limited by choice if we want an easier fitment. The only place this turbo would be faster than the smaller high flow is acceleration from 50km/h or higher. A Garrett 3071 or Borg Warner 6258 or 6758 are much better options for average power "if" you are willing to make them fit. I was told on purchase that the SS2-M35 would be reasonably responsive then to be told on delivery it's response would equal a 3076 .82 with the power of close to a 3071 .6 which I would agree with.
Matt
Edited by BoostdR
  • Like 2
The higher stall convertor is a band aid solution. I would rather fix the problem rather than the symptom. I don't even think it would slip enough for this turbo whilst still being streetable(shaft speed differential for lock-up)
If you are not willing to run E85, aftermarket ECU, upgraded FMIC, big exhaust(from dump back), big intake pipe(3"), big injectors, kitted transmission, big fuel pump, no cat convertor, modded BOV: ==>DO NOT RUN THIS TURBO<==
Matt
Interesting. what Kw are you getting with your stagea, if you don't mind me asking? im going to try my luck with a HX35/2, We shall see what happens lol.
looks like the Holset HX35 has decent Surge resistance I wonder if that is with the anti-surge comp cover which will reduce efficiency up top slightly. There are many factors which will make or break the response. I've seen mixed results.
I don't have a solid figure for the SS2 yet. Giving It the best chance to perform I can. I'll post up results once I've exhausted its flow capacity. I expect 270-300kw
    • So you're now accepting offers of 10% more than the cost of the turbo kit fitted?
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
