hey guys
I have attached a pic of a label on my wife's v35 it's under the lights at the front. Hers seem to be very white so I was guessing there HID but now I'm not sure. Does anyone know a way of seeing what these are?
I am sure this would have been covered before but I couldn't find anything on here. I'm looking at getting her some new lights for her bday but don't wanna have any installation issues
Thanks
Kris
https://www.sau.com.au/forums/topic/442396-v35-lights-halogen-it-hid/
That is the ballast for the hid bulbs. Most of the time they are left on the car to keep the lights water tight even though the light bulbs have been swapped out to halogen for compliance. Only way to tell is to unscrew the large black plastic cover at the back of the headlight and pull the bulb out... Google what the hid bulb connector looks like at the globe end. Halogen will just have a few wires running to the globe whereas hid will have a high voltage insulated connection running from the ballast
Yea definitely hid bulbs in there that is the high voltage ignitor. Small swist to the left and it will pull off. The silver braided cable runs within the headlight to the grey ballast you took a photo of originally. And the normal 12v wires connect to the ballast.
Yeah I have seen that. The ones I want are from the states. I know a few run them but dunno if it's worth the risk. Some point them down so they don't blind motorists. In saying that I have been blinded by cars in the road before and they have been brand new VF commodores.
Can anyone help with what globes etc are used on a 06 series 2. when the compliance was done they put in candles instead of lights, so much so that it is unsafe to drive at any speed (over 80k) on a dark road. I need to put something in so I can see again and this is getting to me.
I'm pretty sure all Commodores and Falcons came out with the driver's side headlight pointing upwards. I have fun flashing almost every Falcadore with my bi-xenons.
I think they're D2R, but best bet is to pull the bulbs out and see what they did (probably use D2 > H1 adapter). Do you have the ballasts+associated wiring still in place?
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
