Hey guys, just a few questions im wondering if anyone to helpout.
Recently installed a Greddy profec 2 ebc on my r34
Everything seems to be work, ihave had a good read on the forums and understabd how it operates,
Although it boosts fine up untill about 6.5-7psi but no matter what I set it to wont seen to go any higher and regularly drops back to about 5-6
Just doesnt seem to be boosting consistanly.
If anyone could shed any light on the situation would help heaps thank you eg
Set, gain, setgain settings and that
Thanks regards
Dan
https://www.sau.com.au/forums/topic/442397-r34-greddy-profec-controller/
Assuming you have no other mods (thanks for including all the relevant information) then you won't want to be running more than about 10-11psi anyway. On that basis, the SET value won't be very high at all - possibly only 25 or 30. SETGAIN (or start boost) will want to be about 7 or 8 psi (or the equivalent in kPa if you've got it configured that way). GAIN will be set to whatever is needed to keep the boost from dropping off at high rpm without causing overboost. Given that the boost controller appears to be not working anyway, you can't waste time even thinking about GAIN at this point, so the value doesn't matter. If it was working though.....it wouldn't set real high anyway.
So, the most likely scenarios are as follows:
1) You've got it plumbed up incorrectly,
2) You've got a faulty solenoid,
3) You've got a broken solenoid loom.
You could have learned all of those possibilities by searching. I know this because there are recent threads on the topic that I have posted in. For this exact same EBC too.
Edited by GTSBoy
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
