Vipec Plug In
Adz2332
 Share
Do they have any external read out capability? ie like the power fc?
I havent been able to get a price on these yet, but what are they roughly worth?
Check out the Racepak Digital Race Dash, I know a few people using those - they plug in via CAN Bus. I am helping a mate build a digital dash for his race car which uses a G4 Link (uses exactly the same comms method as ViPEC) at the moment as well, at this stage it seems like it'd be MUCH cheaper just to make something yourself and it could arguably look nicer as you can customise it for exactly what you want, though we'll see how that plays out in practice. We'll probably just use the serial datastream functionality of the Link/ViPEC as CBF working out CAN atm though will probably have to nut that out at some point.
any pics of what you have done so far mate?
Sounds like something id be into!
Early days at the moment, we've just been playing around with the bits of technology we'll need to put together to make it work to make sure they'll cut the mustard- and generally working out what we'll need to display and how it's all going to tie together.
Here's a small screen I'm using for prototyping things/testing - just uploaded a random clip I happened to have in my phone:
Lol! we'll see how it goes :) It's not really something which is being done with the intent of selling so much as being a mixture between scrooges (not wanting to pay someone else to do something we can probably do as well or better that a lot of other options - same reason for doing DIY tuning etc ;) ) and having new things to play with.
It's not going to end up in a nice packed product so much as something you wire in and hack up to fit lol
Sweet, cheers :) Look into the Racepak dash etc - there are a few CAN bus things out there which should work with the ViPEC/Link, though it depends on how much you want to spend.
That does look good. I would be interested as well lol. How are you transmitting data between the Link and screen?
Would be pretty sweet to make up a dash that utilizes this and some of the stock instruments
Yeah that's essentially what I think my mate is intending on doing, keeping some stock or traditional mechanical gauges and have this for some of the more specialist stuff and possibly warnings etc.
At this stage playing with an Arduino Mega with a RS232 -> TTL converter circuit bridging between the Arduino and the Link, and I am using an LED screen which has a certain amount of processing power of it's own so I can give it a bit of code, too - so it will worry purely about updating the graphs to suit values I pass it via the Arduino, and it "speaks" TTL so I am passing the values of interest to it directly via TTL from the Arduino. The Arduino worries about talking with the Link and getting all the relevant data and any other data processing (mainly handling any odd situations, smoothing data etc) so again the LCD screen just shows stuff it's told to display.
Idea is to set up a system which maintains a good frame rate and smooth transitions so it looks analog, I get sick of seeing digital dash setups which are sickening to watch due to slow frame rates and unprocessed data, so it'd be nice to have it look more like what you'd see in Forza :D
  • 1 month later...
how did you go with this mate?
Still hunting for a decent price vipec plug n play
Haven't done too much on it lately - I have been so busy it's not funny with other projects which are both more much more epic and urgent, but it's not off the radar... just got a lot on my plate and I want a bit of all of it haha.
  • Like 1
 Share
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
