Hi guys.
On the weekend I did the cam belt, tensioners + water pump on my gts25t with brand new 'genuine' Nissan parts. All went smoothly and the car was running fine till this afternoon + a bit of 'spirited' driving caused this:
DSCF0400
The crack runs about 240degrees around the shaft and there is a chip out of it as you can see.
My question is obvious, WHY?
Was my alternator belt so tight it caused this? I didn't use a belt tensioner but I know it wasn't overly tight and the belt is in good condition as is the alternator pulley.
Or was the water pump a faulty product? Can anyone confirm if it is 'genuine' based on this number?
DSCF0401
I just want to get a heads up before I go back to the seller.
https://www.sau.com.au/forums/topic/442422-water-pump-failure/
Water pump bolts were torqued to spec. The belt wasn't tensioned as I don't have a belt tensioner, but I was able to give the belt a 1/4 turn on the top and bottom.
It took less than 30kms for this to happen.
Would it have a chip out of it like that if the belt was over tight?
I'd classify myself as an 'advanced' DIYer. First time doing a cam belt change but not the first time dealing with auxiliary belts.
Thanks, that puts it in perspective. Some guys have absolutely no clue and do things up mega tight.
personally I always err on the side of loose, as you will know if it's too loose (it squeals) but too tight is harder to know.
I don't think many people use a tension gauge.
The thing is as you would know if you are super strong you can get a quarter turn on pretty much any belt no matter how tight it is. Have you been working out lately :)
hmmm that makes it interesting then
why did you put quotation marks around genuine? Was it not from a completely reliable place or second hand or something along those lines?
That might be my only concern now. If bolts were done up right, and sounds like the tension was O.K (without knowing how hard you were turning it to get 1/4 of a turn)
I have my own 1/4 of a turn method that I've been doing for quite a while now on alot of different belts (heavy machinery mostly) and usually is pretty good on your standard v-belts. But as said, I've been doing it my way for years with no issues, but your way and my way might be the same in theory but completely different lol.
Haha, that's a definite no on the working out! My arms got tired after just doing this job.
The parts were from a Nissan dealer, more specifically from here:
http://www.trademe.co.nz/Browse/Listing.aspx?id=715037326
I put quotes around genuine as the cam belt came in a package labelled 'A31 RB20DE' and the water pump is marked '3Y07' which is different from the old one. I know neither of these things are necessarily bad and they might both be genuine and correct parts for an RB25 so hopefully one of you guys can confirm this for me so I can put that one to rest?
When you stripped it down to inspect the damage, was the alternator belt still sitting properly in the various pulley grooves?
Hadn't tried to climb off or anything?
I have seen pumps go like this previously, but they were no-names.
If you break the pump right through at that crack I think you'll be amazed how thin the metal is.
Yeah mate all belts were in line and are undamaged, no nicks out of them or any cracks.
Comparing the old pump with the new, the new one does seem to be a bit lighter and not of the same quality. That could be my imagination telling me what I want to hear though.
Saw this failure on my mates Mazda after we put a new wp on, we went with manufacturing defect but would be interested in other thoughts. (Mechanic by trade so I'm confident in the workmanship :))
I'm sending it back to the Nissan dealer for them to have a look. I'll let you know what they say.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
