Water Pump Failure
thebawse
 Share
Hi guys.
On the weekend I did the cam belt, tensioners + water pump on my gts25t with brand new 'genuine' Nissan parts. All went smoothly and the car was running fine till this afternoon + a bit of 'spirited' driving caused this:
DSCF0400
The crack runs about 240degrees around the shaft and there is a chip out of it as you can see.
My question is obvious, WHY?
Was my alternator belt so tight it caused this? I didn't use a belt tensioner but I know it wasn't overly tight and the belt is in good condition as is the alternator pulley.
Or was the water pump a faulty product? Can anyone confirm if it is 'genuine' based on this number?
DSCF0401
I just want to get a heads up before I go back to the seller.
My correctly tightened belt and your tightened belt could be two different things, and I suspect you have gone way too tight.
To give us an idea, how much mechanical experience would you have?
Water pump bolts were torqued to spec. The belt wasn't tensioned as I don't have a belt tensioner, but I was able to give the belt a 1/4 turn on the top and bottom.
It took less than 30kms for this to happen.
Would it have a chip out of it like that if the belt was over tight?
I'd classify myself as an 'advanced' DIYer. First time doing a cam belt change but not the first time dealing with auxiliary belts.
Thanks, that puts it in perspective. Some guys have absolutely no clue and do things up mega tight.
personally I always err on the side of loose, as you will know if it's too loose (it squeals) but too tight is harder to know.
I don't think many people use a tension gauge.
The thing is as you would know if you are super strong you can get a quarter turn on pretty much any belt no matter how tight it is. Have you been working out lately :)
hmmm that makes it interesting then
why did you put quotation marks around genuine? Was it not from a completely reliable place or second hand or something along those lines?
That might be my only concern now. If bolts were done up right, and sounds like the tension was O.K (without knowing how hard you were turning it to get 1/4 of a turn)
I have my own 1/4 of a turn method that I've been doing for quite a while now on alot of different belts (heavy machinery mostly) and usually is pretty good on your standard v-belts. But as said, I've been doing it my way for years with no issues, but your way and my way might be the same in theory but completely different lol.
Haha, that's a definite no on the working out! My arms got tired after just doing this job.
The parts were from a Nissan dealer, more specifically from here:
http://www.trademe.co.nz/Browse/Listing.aspx?id=715037326
I put quotes around genuine as the cam belt came in a package labelled 'A31 RB20DE' and the water pump is marked '3Y07' which is different from the old one. I know neither of these things are necessarily bad and they might both be genuine and correct parts for an RB25 so hopefully one of you guys can confirm this for me so I can put that one to rest?
When you stripped it down to inspect the damage, was the alternator belt still sitting properly in the various pulley grooves?
Hadn't tried to climb off or anything?
I have seen pumps go like this previously, but they were no-names.
If you break the pump right through at that crack I think you'll be amazed how thin the metal is.
Yeah mate all belts were in line and are undamaged, no nicks out of them or any cracks.
Comparing the old pump with the new, the new one does seem to be a bit lighter and not of the same quality. That could be my imagination telling me what I want to hear though.
Saw this failure on my mates Mazda after we put a new wp on, we went with manufacturing defect but would be interested in other thoughts. (Mechanic by trade so I'm confident in the workmanship :))
I'm sending it back to the Nissan dealer for them to have a look. I'll let you know what they say.
 Share
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
    • If it has had a code in the recent past, the code should still be there waiting to be read.
