once again mike youve outdone yourself,thanks for an awesomely organised north cruise,apart from one hick up was a great day had by all,also would like to thank the 350z guys for turning out,hade some pretty impressive cars,also proved that you can get 400kms out of an rb,just did it,hope to catch up with you guys at qr happylaps. :yes:
bummed I had to bail at Woodford, a mate was involved in an accident with the R31 cruise just down the road at Cabo, total of 3 cars written off including his in two separate crashes :(
thanks for organising this once again!
Jesus, how did that happen?
son of rajab, how did that happen?
31 drivers...
Good day. Lunch was awesome.
Shame about the c*cknugget in the blue GT-R, but I guess you can't have everything...
Thanks Mel for letting me drive Pinky, Mouse for organising a great cruise, and everyone else for making it a great day!
  • Like 1
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
