1990 R32 GTR RB26DETT - $22,000 ONO - 0422626173
Up for sale is my 1990 Nissan skyline R32 GTR, It is in great condition with 84,000kms and the original japanese service books, it has been used as an occasional weekend car.
Panasport G7 C5C 3 piece wheels with Federal 595 RSR 255/45/17 (1500kms on tyres)
Greddy Type S Coilovers
Cusco rear camber arms
Cusco castor rods
HKS pod filters
Greddy Cam Gears
HKS Power FC with hand controller
New Nissan injector seal kit with new Pintle caps (installed less than 300kms ago)
HKS electronic boost controller
3.5” catback exhaust with 4” oval rear muffler (nice and quiet)
RDA slotted and dimpled rotors with Intima SR brake pads (installed less than 1000kms ago)
Genuine Nissan Tie Rod ends (installed less than 1000kms ago)
Rebuilt Drive shafts with new CV boots (installed less than 1000kms ago)
Steering Rack boots (installed less than 1000kms ago)
Rebuilt Headlight Switch (installed less than 1000kms ago)
Wheel alignment performed by Capital Steering less than 500kms ago
Will come with standard ECU, used Z32 AFMs , standard castor rods, rear camber arms and a spare drivers side window
https://www.sau.com.au/forums/topic/442457-1990-r32-gtr-22000-act/
  • 3 weeks later...
The pillar trims are out of the car as I am looking to replace the old ones with a new set from nissan
How much were the pillar trims? im actually looking to get a new set too - GLWS
It's a very nice one Terry.
Jimmy parked next to mine at a local Shannons gig recently.
I gave it a good look over and It looks honest to me.
I'm sure he'll will provide pics/info soon.
  • Like 1
Any rust Jimmy?
Got pics of the onside & engine bay?
Who was the importer?
Any de-reg?
I will have a look through my papers and get back to you on the import details
The car has a few small superficial surface rust patches on the undercarriage but its definitely nothing concerning or structural.
Here is a video walk around of the car including interior and also the engine bay
I just bought a new set for my V-Spec 2.........
Part Numbers are as follows:
  • NI-76934-04U00
  • NI-76935-04U00
Nissan List price $159.70 ea + GST = $175.67 ea.
Cheers,
Bob.
  • NI-76934-04U00
  • NI-76935-04U00
Cheers,
Bob.
Thanks mate!
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
