Hey guys so this is the car i baught 1 week ago.
currently got a nissan r33 1993 gts as my daily as im a P Plater in Victoria :(
But baught this 96 gtst for 5k on the weekend. needs a few little things other than that im in love. list further down of everything that ill be doing.
This is the day i drove it home. misses drove my gts to get me up there.
10270967_10202626383313240_886755486_o_z
Model Skyline R33 series 2
Heres 2 quick photos i took of it this morning.
The car is completely stock apart from a pod filter and cat back exhaust the previous owner had fitted.
Engine bay shot.
He also gave me a 13 silicone hose kit. but i could only find 1 hose apart from the 2 radiator ones that actually fitted. as you can see. so looks stupid.
plan on doing the cheap quick free mod on the weekend. with the boost controller by putting a ground switch in the cab so if i want it to full boost straight away isntead of waiting till 4500. i switch the switch. :)
In need of replacing my coilpacks as they missfire past 4500. tried replacing sparks helped alot but missfires still there. so gonna try recondition them on the weekend clean out and put some dielectric compound on the rubbers ect see if ti fixes it if not splitfires it is.
Just serviced it last weekend.
Spark plugs
oil filter
oil
fuel filter
and re mounted the pod as the previous owner broke the bracket and thaught itd be good for me to drive it home without a filter on. dick head....
had it zip tied for the drive home ahha.
will be doing stuff to this neally every week-2 weeks so thread will eb updated regularity.
any suggestion ect are welcome.
My wants
are a return flow cooler.
power FC (or any other respectable plug in replacement ecu.
pump the PSi up to 11-12. further down the track i want to get the direct replacement hiflowes from hypergear i think its called.
getting a bellmouth dump/front pipe fitted with a hi flow cat within the next few weeks also.
cant wait. need to get rid of the huge cannon on the back though.
https://www.sau.com.au/forums/topic/442473-mattz-96-33gtst-build/
So on the weekend i bought a couple of things.
a boost gauge and pod.
I decided to mount it on the A-pillar. run the vacuum line from the factory boost gauge vacuum line. Td into that. and wired it all up to the cigaret lighter wires. for light and ground ran a separate constant power for the Ram to remember which color is set.
I think its mounted in a good spot
Also as i didnt replace my fuel filter the other day i replaced that also. i must say those fuel lines are so hard to get off. haha.
Few questions for maybe some well known members that know alot fo trouble shooting for skylines. got a missfire at 4500 RPms i changed my plugs. didnt fix it, yesterday i pulled the coils back off cleaned them up and put Di Electric silicone compound on the inside of the boots ect.
may of helped a bit but not really still at 4500-5000 the missfire jumps in. afm is in good condition. thaught maybe it was a fuel restriction due to the fuel filter. not knowing when it was last changed. but that didnt fix it today. you guys recon its coilpacks?
If so whats the best option to go.
OEM
Splitfires.
Ive heard of LS coils what are these? a cheaper good option where do i get them what are they called?
much appreciated guys. thanks.
I have ls coils they are off chev v8s they can all be used but are not as tidy as the standard coils they require a custom bracket and wiring they are cheep and got a fair bit of power in them but need the dwell times changed to get the most out of them.
The standard coils are proven they have lasted around 20 years but are costly for new ones. I have some with 800kms sitting around here but are for a s1 that I plan to sell cheep.
As for the split fires I can't comment don't know much about them.
Thought so just didnt wanna sound dumb by saying were they for Ls like ls1 ls2 ect haha. thanks man.
so i guess its an option but only if done neatly otherwise will look messy. may i ask why you went with LS if you had perfectly fine ones?
P.S does the factory harness need to be re wired and LS plugs to be bought ect. or are they a good option as there plug straight in?
Edited by MathewZ
So been having a lot of issues with my speedo lately. The other day when i was driving along at 80 all of a sudden bam no speedo. hit the cluster a bit made the speedo go up then down again then not at all nothing. pulled over, shut the engine off waited 5 minutes turned back on, and nothing.
So tried resetting the trip computer. may have worked? didnt though haha. so drove slowly back to work. to pull all the surround off. i found some screws on the back of the cluster loose tightened them up went for a drive seemed to of fixed it. and just 3 days ago again bam lost speedo. pulled it all apart again. checked my plugs all contacts seem in good condition. and again the screws were loose again. screwed them all abck up. mind you my dash doesn't vibrate at all so dont see why there going loose. also i took 2 pictures of my cluster.
Looks to me like theres atleast 8-10 screws missing and 2 bulbs. not sure if this is normal or not. anyone can ilaberate maybe if they are pretty familiar with the S2 cluster haha? heres 2 pictures.
. I changed to the ls coils because my igniter shit itself so I decided I'd just get rid of it and get smart coils and I guess I was just bored and wanted something todo haha the harness needs to be modified to suit and an extra earth to the ls coils as they are 4 pin and the rb coils are a 3 pin didn't take me long to redo the full engine loom helps to be an auto sparky.
the missing screws are normal also.
But hows your fuel economy running that much all day ery day?
was only thinking for it as i want to be able to say run 8pound then when i feel a bit naughty switch it to 12(different turbo) 18-20. as im at talks with a local tuner for future modifications.
Decided to get new OEM replacement coilpacks through my tuner as he recomended them as being as good as splitfires and sees no problems with them running the type of power im cahsing. and the extra $$$ i spend on splitfires could go towards other things.
So picking up a turbosmart Tee to fiddle with the boost a little. not going to go over 10 but atleast i can run 8pound allways without doing the cheap 8pound permanent fix. by grounded the solonoids earth wire.
Picking one up for $50 tomorrow. also a 42mm second hand but in good nic alloy radiator. so will be able to chuck my Blue silicone hoses on too. haha.
What are peoples thaughts on running 10pound untuned ive seen mixed results. varying from car ran perfect no hassles what so ever. to some having slight problems.
will be no updates for 2 weeks after this post as im goign into surgery this friday. and will be out of action for 2 ish weeks. atleast ill have some goodies to put on when i get better. Pictures to come when purchased. just casue i love sharing :D
My fuel economy is shocking lol - I get about 300km to from an absolutely full tank. It makes nearly 300rwkw though ;)
Control boost with your right foot. You'll probably find you'll leave it in high boost mode most of the time anyway.
New OEM coilpacks are the way to go. They can handle big power if new or in good condition.
The factory ECU's vary in regard to how much boost they can handle without going into R&R. 10-11psi is usually about the limit. Same goes for factory turbo.
TurboTech MBC's are generally regarded as better than the Turbosmart MBC due to being a spring and ball as opposed to a bleed valve.
Wouldnt a bleed valve be more reliable. as over time wouldnt the spring inside a Turbotechs MBC would slowly loose tension. therfore changing boost pressure without adjusting, im not speeking of like 2 weeks but like over 1-2 years. would it not loose tension.?
Not sure about them wearing out, there's plenty of people who have been using them for years with no problems. The problem with bleeds is just that, they bleed air, meaning the wastegate begins to open before full desired boost is reached, hurting response. Ball and spring type valves hold shut until desired boost is reached and then open.
There a whole bunch of threads on that topic, and they general consensus is that the TurboTech is a better product overall. They're cheap too :thumbsup:
Nice car by the way, it looks like a clean base to start with.
So picked up a few things last night.
Wish i had seen your post earlier about bleed valves killing the response apposed to spring and ball operated BCers
Well anyways. i got this cheap as so if i do find it not very responses i can always get the Turbo Tech Ones.
Then Picked up a second hand out of a 33 my mates stripping. alloy 42 MM radiator. going to be giving it a good clean out and polish. still has the old hoses on at the moment until i get round to putting it in. and polishing it up too look nice and SHINY :D
Nother shot
Also got these blue silicone hoses to go on when i put it in.
Will be picking up a set of new OEM coilpacks sometime next week. and hopefully put it all in not this weekend but the following.
Going in to hospital tomorrow so will be out of action for a week or so depending on recovery.
But KEEN as to get these all in.
Probably going to put the Turbosmart in. but hide it and keep the factory controller the with fake vacuum lines on to make it look stock. but not. as ill be needing a RWC further down the track when i plan to register this.
Going to make the turbosmart just run on 8PSI like stock. for now. unless people recon running 10 without a tune or FMIC nor Downpipe and cat is safe? if not im in no rush so probably just run it on 8Psi anyways.
Also plan on getting a body kit within the next few months. Want a GTR front bar. GTR spoiler 400r skirts and undecided rear bar as of yet.
Possibly not the gtr spoiler though. seen alot of drag style spoilers around lately. pretty keen on them too. or the Do Luck boot lip spoiler. haha.
So been looking around alot for turbo options.
id love to get a top mount manifold and top mounted turbo just for the pure Sexyness look. but dont want to really get anything liek that if a cop pops the bonnet and defects for it. being an Intake modification.
Are top mounted turbos defectable in victoria ect?
Ive seen this seems very cheap but wondering what others opions are if anyones had one.
i know theres hypergear. GCG? i think and TOG this tog seems the cheapest.
http://togauto.com.au/product/tog-nissan-skyline-r32-r33-r34-rb20det-rb25det-bolt-on-turbo-480hp-gtst-gtt/
Direct bolt on with few modifications. intake pipe ect.
seems very cheap and if good wouldnt be a good bang for your buck option. but then again ID love a top mounted torubo. i dont want crazy power so no 6766 precision turbos or anything. just want really 250+ KWs with a nice engine bay. but are top mounts legal? if not can they be made Legal. ?
ive heard of one place saying they have a botl on turbo like Hypergear except better. wouldnt give me any details weirdly. and said id get 280-300kws with just the turbo and intercooler and downpipe....
Id love to know of a good skyline tuner around melborune. preferably in SE dandenong ringwood area kidna thing. that maybe i could talk to? that anyone knows has a great reputation with skyliens and tuning. very hard when you dont have many contacts or friends tuning wise that you can ask.
i was recommended a guy in Dandeong Force motorworx. yet me asking too many questiosn seemed to angry him and he stopped contacting me. even though i was going to buy parts through him. like my coilpacks ive mentioned im getting.
so any good parts suppliers/tuners aroudn SE Melbourne please thanks guys. thats fi anyone reads my posts anyways haah. seems to get alot more veiws than posts haha.
Thanks.
PS i know quite a few people go with the garret gt3076r turbo. Tog do one of these for 1/3 the price. wouldnt mind knowing if anyones gotten one. and how they went if its worth goign cheaper or just pay the 1500 for a garret.?
also ECus. i knwo for tuning ill need a piggieback or new ecu Powerfc ect ect. what do you guys suggest. going the Power FC. i dont want the hand controller as i dont want my interior to start looking all modded and shit. whats the best cheap way for ECu . shoudl i find a piggy back? just get a power FC. ect theres too many options ahah.
Edited by MathewZ
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
    • Oof. Could be worse I guess. I suppose they haven't put any effort into ally suspension parts or CF panels, seats, etc. So they could probably pull about half of that back out of the car. Not like a bunch of other EVs that already have CF everything and roll the scales at ~2t.
