A few, several, years ago I fitted an FFP in accordance with instructions I got from a DIY on the Skyline forum. Since then the engine seems to have been plagued with fits of the "gurgles". And, after a trip to the coast and back the radiator level is nearly down to the tubes and the overflow bottle is nearly empty.
There is no oil in the rad and there is no water in the oil.
Where, how and/or is the water going.
https://www.sau.com.au/forums/topic/442474-where-does-the-water-go/
well, it may not be the FFP, it doesn't have an coolant does it?
the best way to sort this sort of thing is a radiator pressure test; any mechanic should be able to do it free or cheap. It will confirm if there is a leak, and you can often hear exactly where the leak is coming from. small leaks are generally radiator cap faulty, pinhole in the radiator (what I just had)
The FFP has a coolant chamber, Could there be a leak into the intake that can be recirculated via the exhaust back thru the turbo to the intake etc.
I will take all this advice on board and once I finish my other issues this will be my priority
For my Dayz rebuild I am thinking of going Plazmaman. That way there is a lot less modding to do..
What about your heater core? If you ever smell coolant in the cabin or notice stains on the carpets around the footwells, could be that. Can get over looked during pressure tests because they dont always cause big enough pressure drops when they first start to go.
Hate to be the worst case scenario guy but head gasket?
My Cressida (different car I know but similar symptoms) used to eat coolant, and number 6 spark plug used to get rusty.
If it sat for a week or so, it used to cough when you first started it until it cooked the water off.
Those things were renowned for blowing them after toyota ballsed up the head torque specs but mine went softly rather than properly.
It never got hot, just used to slowly empty the rad...
Kept driving it for a year, didnt get much worse, sold it cheap-cheap...
Edited by shane344
Is it being bled properly when it is filled?
Sure is. Top up with Coke bottle header so plenty of water above bleed valve, Even raised bleed about 75mm. Always bleed with heater on.
sound like the bleed wasn`t long or good enough , if its gurgling then there is still air in the system somewhere , may need a pressure bleed. I always use a funnel and piece of tube 300+ mm .but you may require somthing different,
To keep up to date..
Tried a new rad cap. No improvement.
Pulled the thermostat out and tested. Opens at 65C. So that seems OK. It was a sod to get out and worse to get back in.
Neat time I will go Plazmaman FFP.
From what I have seen so far it clarifies why my oil temp goes to 115C coming up the mountain,because by that time there is not much water in the radiator.Methinks? I have closed the loop on the heater so there can be no leak there.
When I drained the rad the water was fairly rusty and there was a lot of crud in the thermostat housing. I had been using good coolant addative but can see how diluted it has got over time. As a precaution I am getting the radiator cleaned and tested. Am sure the water pump works as when revs over 21/2
makes liquid spout out of the bleed valve and the radiator fill point.
When bleeding I use a large Coke bottle full fo reservoir and have lifted the bleed valve up 100mm.
If all this fails it will be off with the Greddy FFP and back to the stock intake. See how that goes and if OK will leave it on.
Isn't there a small nut to crack or something on the Oem manifold system to clear air when bleeding the car?
I'm far from the RB expert, but I think someone mentioned it, worth a search anyway. Did your manifold delete this?
Pretty hot for a bath, but not an engine. It's too cold.
Neos run at 82. I think pre neo is a touch cooler but not that much.
I recall my vl turbo running at 82
Edited by superben
I find it unlikely that FFP is to blame. If you are going to all the trouble to remove thermostat you should have put a new OEM one in place. They should open at more like 80deg or more - 65 deg is not hot.
Did you get a pressure test? A radiator shop shouldn't charge you for it. If the pressure doesn't go down then maybe you need a new radiator core - I see you are getting yours cleaned - that may well fix your problem.
An early opening thermostat won't cause overheating or coolant loss, so it's not crucial to change it anyway. If there was a lot of rusty coloured water and or scale your rad was most likely not efficient anymore.
Might not be a total fix for your probs but good idea getting it serviced anyway.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
