After some advice, my car needed an engine rebuild gearbox rebuild n a new clutch, so I ordered in a new nismo twin plate copper mix comp spec clutch from rhd in japan. But when the mechanic went to put the clutch in turns out a previous owner has converted it from pull to push type, an the clutch I got was a pull type (car is a 33gtr). Wot are the options? Don't really want to freight the clutch back to japan an freight a new one in even if rhd were okay to do that.
  • Like 1
https://www.sau.com.au/forums/topic/442496-so-i-got-the-wrong-clutch/
To run an expensive push type clutch.
You mean inexpensive? As pull type clutches are more costly than push types.
Or you mean it's only expensive because you have to do the conversion and then by the clutch on top? :)
Expensive as in a $2k clutch, but yes, I'd imagine pull types might have been more expensive outright purchase and servicing wise. Please note the time stamp hahaha.
I remember seeing (I think) ORC clutch kits with the converter, no idea if they ended up costing more than the equivalent pull type.
If you get the right kit from new it will come with the correct bear etc
Company's like OS giken and others only make push clutches, so sometimes to run a really serious clutch you might need to go push.
I've changed between the 2 many times and the OS Giken pull to push kit is literally a few bolts and a different fork.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
