Sau Vic 2014 Motorsport Championship Round 4 - Winton Saturday 17Th May
So already had it checked out and bad news?
Dont need it checked out to know its bad news lol
Only thing I could think of causing such a slow and subtle failure would be from oil surge/starvation. I'll get it looked at when I feel like looking at the car again :(
That's unfortunate Lee :(
Seems some had a great day, others the total opposite.
Good fun overall none the less, good day to come up for some laughs from my point of view
Same here, awesome day and thanks for the BBQ!
How did your pics turn out Peter?
Haven't had a chance to go through them all but hope to share some pics by end of the week.
I got too lazy to take many photos after the feed at lunch! haha
Hopefully P1 race photography photos get published this time!
  • Like 2
That's a good camera setup John, the off could have gone worse!
Looking forward to some more pics, coverage of recent rounds have been good.
Here's mine, it's all rather calm and quiet compared to everyone else. Maybe I need classical music and a cardigan hehe...
  • Like 1
Guest
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
