Seller Details
Phone: 0424 141 211
Price: $23500.00 Negotiable
Vehicle Details
Transmission: Factory 5MT
Year: 1998
JZX Type: X100 Chaser Tourer V
Colour: 6N9
KM: 123xxx
Additional Details
After a lot of thought I have decided I want to look into getting a cheaper daily/newer car. This is my third X100 and easily the best one that I have owned. It has been very reliable and a rewarding car to drive on the street and also the occasional track day. I received the car almost stock and all of the mods/parts/services have been done by myself or with the JZX guys @ 612 Autoworks. Many parts are less than 5000KM old. I am putting up the car as a complete package, but am willing to negotiate removal of parts for price adjustment. The car currently has rego up until end of May, however a renewal + RWC can be discussed. Here is a list of specs and some photos further down. Please contact me via mobile for any questions.
Maintenance
100k service completed
General service completed Tuesday 28/04/2014
New OEM diff bushes
New Redline transmission fluid
Diff fluid replaced
Refreshed clutch master cyl
New clutch slave cyl
Mods
Power
Blitz K1-450V Turbo
HKS Actuator
Blitz Air Filter
HKS Intake (J-Pipe delete)
Blitz FMIC
Denso 850cc injectors
Walbro 255LP/H fuel pump
Stupid rare Trust DD twin pipe exhaust
Koyorad 2layer copper radiator
Action Stage 3 clutch (Rated to 370rwkw) from US
TRD Radiator cap
HKS F-Con V Pro V3.14 ECU w/3Bar map sensor
Turbotech bleed valve
Tuned by Trent @ Chequered Tuning. Makes 240RWKW & 460NM of torque by 3200RPM (16psi)
Brakes/Susp/Wheels
Znoelli slotted front rotors
Znoelli front pads
Fresh OEM rear pads
Almost new Silkroad RM/A8 coilovers
TRD swaybars
Tom's triangle brace
18x9/10 Blitz BRW 03 rims
Nexen N6000 all 80%+ tread
GSP purple wheel nuts + lock nuts
Interior/Exterior
OEM weathershields
No spoiler boot (no holes)
Rare OEM factory rear visor
TRD gear knob
2x Bride Brix 1.5 seats on genuine superlow rails
Polk audio speakers
Alpine head unit
Alpine 5ch amp
Mongoose M80G 3pt immobilizer/alarm/keyless entry
Things that may need attention in future (I want to be completely honest about condition as the car is a very solid package overall)
Castor arm bushes are a bit cracked
Rear upper arm bush has a bit of play
Rear quarters have inside-out pin dents (common on these cars due to only a single skin panel)
Drivers mirror has a bit of free-play movement
General wear and tear on paint few scratches here and there. Front bar and lip has stone chips etc.
Small scuff on corner of rear bar
Pics (will update with better pics next week, some of these are few months old with different rims)
Swap for a supra ?
Sorry not really looking for a swap. Have my eyes on a car I'd like, so happy to hear offers!
Considering putting stock turbo/ecu/injectors/intake all in to reduce the price a fair bit since ppl seem to want a more standard car.
Price drop $19,500ono with standard seats/rims/visor. Am negotiable so please call/msg me with any offers or to arrange an inspection!
Also forgot to add I've just paid 1 year registration :)
Edited by discern
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
