Seller Details
Phone: 0424 141 211
Price: $23500.00 Negotiable
Vehicle Details
Transmission: Factory 5MT
Year: 1998
JZX Type: X100 Chaser Tourer V
Colour: 6N9
KM: 123xxx
Additional Details
After a lot of thought I have decided I want to look into getting a cheaper daily/newer car. This is my third X100 and easily the best one that I have owned. It has been very reliable and a rewarding car to drive on the street and also the occasional track day. I received the car almost stock and all of the mods/parts/services have been done by myself or with the JZX guys @ 612 Autoworks. Many parts are less than 5000KM old. I am putting up the car as a complete package, but am willing to negotiate removal of parts for price adjustment. The car currently has rego up until end of May, however a renewal + RWC can be discussed. Here is a list of specs and some photos further down. Please contact me via mobile for any questions.
Maintenance
100k service completed
General service completed Tuesday 28/04/2014
New OEM diff bushes
New Redline transmission fluid
Diff fluid replaced
Refreshed clutch master cyl
New clutch slave cyl
Mods
Power
Blitz K1-450V Turbo
HKS Actuator
Blitz Air Filter
HKS Intake (J-Pipe delete)
Blitz FMIC
Denso 850cc injectors
Walbro 255LP/H fuel pump
Stupid rare Trust DD twin pipe exhaust
Koyorad 2layer copper radiator
Action Stage 3 clutch (Rated to 370rwkw) from US
TRD Radiator cap
HKS F-Con V Pro V3.14 ECU w/3Bar map sensor
Turbotech bleed valve
Tuned by Trent @ Chequered Tuning. Makes 240RWKW & 460NM of torque by 3200RPM (16psi)
Brakes/Susp/Wheels
Znoelli slotted front rotors
Znoelli front pads
Fresh OEM rear pads
Almost new Silkroad RM/A8 coilovers
TRD swaybars
Tom's triangle brace
18x9/10 Blitz BRW 03 rims
Nexen N6000 all 80%+ tread
GSP purple wheel nuts + lock nuts
Interior/Exterior
OEM weathershields
No spoiler boot (no holes)
Rare OEM factory rear visor
TRD gear knob
2x Bride Brix 1.5 seats on genuine superlow rails
Polk audio speakers
Alpine head unit
Alpine 5ch amp
Mongoose M80G 3pt immobilizer/alarm/keyless entry
Things that may need attention in future (I want to be completely honest about condition as the car is a very solid package overall)
Castor arm bushes are a bit cracked
Rear upper arm bush has a bit of play
Rear quarters have inside-out pin dents (common on these cars due to only a single skin panel)
Drivers mirror has a bit of free-play movement
General wear and tear on paint few scratches here and there. Front bar and lip has stone chips etc.
Small scuff on corner of rear bar
Pics (will update with better pics next week, some of these are few months old with different rims)
Swap for a supra ?
Sorry not really looking for a swap. Have my eyes on a car I'd like, so happy to hear offers!
Considering putting stock turbo/ecu/injectors/intake all in to reduce the price a fair bit since ppl seem to want a more standard car.
Price drop $19,500ono with standard seats/rims/visor. Am negotiable so please call/msg me with any offers or to arrange an inspection!
Also forgot to add I've just paid 1 year registration :)
Edited by discern
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
