tuner told you to change *what*? as it was running rich? dont tell me the tuner did a *over the phone* touch up of fuel mapping when you yourself have no idea. sounds pretty irresponsible, especially via the hand controller. sounds more like you accidentally wiped it..
did tuner have you play with the air flow meter options? sure its not on z32's or some other afm?
Hi Dave
The car was stuffed, would not idle for long, sounded like rattling a can of nuts and bolts at idle and when I tried the boost it was crap,BUT at about 1400 revs to 4k ish it sounded fine, I am stuck in the bush on a shitty Rd so I mothered it home under 3k
He sent the hand controller to me and we went to the settings using Face Time, he was in control of the situation, he could SEE everything and guided me through it, not rocket science when you have the tuner guiding you, he saw that the ECU had gone back to original/factory settings.
The car was running very rich, so we changed the settings to fix it and a couple of other settings, then I took it to my mechanic to check the motor was OK and change the plugs, they were BLACK.
I do not know if the changes will stay there and not keen on it going pop again on the way to Sydney, so he has offered to load his loaner ECU with my tune and send it to me to get me back to Sydney.
I may be wrong but I think he did everything he could from 350Klms away to help me out of a bad situation and professionally ..
This does not mean I am happy that the FN thing went pop after 300Klms after just having work done including a NEW Tune:(
Have you checked for boost leaks/popped cooler hoses?
You really should...
And I am 10000000percent sure you don't need a motec!
There are plenty of ecu options. Look for one that is plug, eg link or vipec yo name a couple,
To be honest I do not know what to get, but if I have to change the ECU I want something that if I have a problem in the future I can save the tune and I can reload the tune from a memory stick or whatever, well that is if this sort of thing is available to us mere mortals ??
The tuner was on Face Time with me and we went through everything he wanted to see with the hand commander he sent me before saying what he though had happened and recommended a new unit instead of replacing it with the same 15 + year old Apexi unit and suggested using new tech unit?
interesting.... you could spend a couple of hundred dollars on a fc datalogit so that you can save your tune to a laptop....this is what is available on all the other ecu platforms...however not many of them have this handy dandy hand controller.
Had a very similar experience myself, turned out to be clogged up fuel filter from me starting to use the part ethanol fuels as well as a intermittent fault in one of the MAFs. Stuck a Link g4 and map sensor in it to update the package a bit ( ie removed the powerfc). was sick of MAF issues anyway. Within 3km of filling up with 90-10% ethanol, it was running like a hairy goat. Sometimes things can compound till it brakes the camels back, as in my case where car was very drivable with occasional issues from Maf, but throw in a couple of other factors and it brings it down.
haha, everyone is out for a buck $
When you see this gizmo in action, "The hand commander FC" and someone 100s of Klms away changing what your motor is doing(simple when you know what you are doing) by guiding you through some simple adjustments , cars take on a new look, shit this is space stuff watching and hearing your car sounding different, running like crap to sweet by changing a few settings on a gizmo.
I just wonder when it is time to get new tech into your car, seeing I have a problem, maybe it is as good as time as ever to do it?
But I think I will send the Apexi down to the tuner and have them load the tune again and send it back so I can try and use the car until they can do all the work I want done
The hand controller for PowerFC is mildy convenient. But compared to accessing ANY ECU on a laptop, including PowerFC, it is like using a hammer and chisel compared to a dremel.
Totally agree, when tuning a car copy and paste becomes an essential function lol
There is a lot to learn, bloody cars :)
I have had a lot of cars but with this R34GTR it is the first time I am interested in more than just driving them
There are different ideas of what is the best brand/model# and I understand that price can be a major factor, maybe someone could recommend a package of what I would need , ECU , brand and model# and whatever can be used to make it user friendly, I am not the best with computers but OK once I get my head around most things, sometimes just enough to be dangerous :)
But if I buy something I want it to be able to do everything you need it to do.
ive got at least 1000 tunes saved by their number plate in a database... organised by country / city / ecu.
and i make backups.
What do you do with these, is it just a hobby or useful??
Your best bet, if you are happy with your tuner, is to ask what they recommend and get it from them.
That way you know they are happy and comfortable tuning it.
they said the Haltech, I would like a unit that most tuners would be happy with, if possible?
As I live a long way from Sydney I was hoping to get this last work and tune done in Sydney and hopefully find someone closer.
sent the Apexi to Sydney , the tune was reloaded and sent back to me, put it back in the car and away it went, got me stuffed??
Anyway off to Sydney tomorrow to have the Haltech installed, also a Walbro 460Lph fuel pump and a custom exhaust as mine is very restrictive ,looking forward to see the difference in performance and sound :).
I wonder if they can load the new tune from the Haltech into my Apexi , I would have a back up but I guess this cannot be done as they are different brands :/ ???
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
