hey guys just intsalled a walbro in my r32 gtst it works cause its on and your can here it , just my car wont click over , fuel is pretty low so ill try put more in it this afternoon but normally theres enough for it still to go for a littlwe while before the fuel light would even come on
is there some way i can check or ?
https://www.sau.com.au/forums/topic/442565-r32-gtst-walbro-fuel-pump-problem/
How low did you mount it?
A pressure gauge would be best. But ghetto option would be to pull fuel line off and spray fuel everywhere , or not.
Did you get feed and return correct on the lid?
oh okay , yeah i dont think the hoses even swapped over they stayed on the same side where they were so assume there right
I certainly wouldn't assume it.
You really should have marked one before taking them off.
Trust me, the first time you don't look the hoses swap sides just to screw you over!
If mounted correctly you should be able to run the tank virtually dry with the new pump.
