HKS camshafts brand new in the box from Australian Distributor
2202-RN130 Nissan RB26 R32 33 34 GTR - INLET, Duration 272. Lift 10.2mm Step 2
2202-RN131 Nissan RB26 R32 33 GTR - EXHAUST, Duration 272. Lift 10.2mm Step 2
Selling due to buying a complete built head that has the same cams in it already
Paid $1000 selling for $750
Need them gone this weekend no reasonable offer refused.
Call 0421656791
  • 8 months later...
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
