having created butthurt over at micra hq, ill predominantly update here. seem the old guard dont like it when two blokes get together in a shed and build something good (but not necessarily better) for 10% of what they have spent.
now i know it was a roller dyno, so the 169kw wont be spot on, but f**k. chill the f**k out.
oh well. i didnt set out to build australias most powerful micra, (even if i have, ITS A MICRA WHO GIVES A f**k)
they are seriously as bad as honda owners. haha. any way, research and emails have gone out to start the handling/traction upgrades. some 6 inch wide wheels with 205s and maybe an arch roll.
an old viscous lsd etc..... we will see what happens. for now im just gonna drive it.
also, can anyone point me in the way of custom mls head gaskets? i can go nissan, nismo(which ups the compression so a big no no) or copper, which im not fond off.
  • Like 2
That's a big bump, on 10psi boost with E85 I'd be ok at 10.5 but a lot happier at 10, I've got 9.5 now and am jamming 28psi into it :D
LULZ.
we will find the limit of this engine one day. but i need a spare ready to go in., this is my daily for the next year. or until i get bored.
i do have the wrx to fall back on, but dont wanna have the micra off the road for more than 2-3 days.
I depends how you split your moneys, i see it as tyres are a consumable like fuel and rego though if your going through tyres at the same rate as fuel you've got an issue
Engines aren't much different to tyres, especially if you own a RB26 :yes:
  • Like 1
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
