I depends how you split your moneys, i see it as tyres are a consumable like fuel and rego though if your going through tyres at the same rate as fuel you've got an issue
Engines aren't much different to tyres, especially if you own a RB26 :yes:
hahahahah. i like this. alot.
the wife wouldnt tho.
having created butthurt over at micra hq, ill predominantly update here. seem the old guard dont like it when two blokes get together in a shed and build something good (but not necessarily better) for 10% of what they have spent.
now i know it was a roller dyno, so the 169kw wont be spot on, but f**k. chill the f**k out.
oh well. i didnt set out to build australias most powerful micra, (even if i have, ITS A MICRA WHO GIVES A f**k)
Sorry, I seem to have accidentally stoked the fire. :P
my mini gtr just scored some mini gtr wheels.
mucho happio. 14x6.5 et 35. 205's come at me.
they actually do look like mini R33 GTR wheels
abbey snot rocket will look tits
seriously ants whats this abbey all about?! lol
yea i spotted em last week and really wanted em, but the guy is only avail 9-4 mon to fri over the other side of the city. so i had no chance.
then sir grant steps up, and pow. should have me some wheels on friday. just need a joint in the south east to open the centre bore up for me.
nice. What did Gnart do to speed things up?
Every car should have a nick name - Abbey Snot Rocket just suits ya lol
no. it doesnt.
hes picking them up friday.
now guys says hes find a buckle. f**king.
not that im too worried. look repairable and i can just stick it on the back
alright gents. how have we been?!
after a spirited drive on saturday (finally getting used to this thing!) i woke up sunday morning to see a small patch of oil under the car.
got her up on ramps, and found out that the rear main seal, installed about a month ago, appears to be leaking.
now seeing as i currently have 3 other cars at my disposal, i decided to fix her over time, so i started with disconnecting everything.
im in two minds as to weather i should do the head gasket/turbo/timing chain/arp studs now...... all comes down to money i guess, if i get my bonus and tax cash before shes back on the road ill get it done.
this will be the last update on the car affectionately nicknamed by my wife as "the green turd" thanks for that mcm.
for a while anyway. she will be back by the end of september.....
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
