yea man, thanks!
honestly. its the dump.
has to be.
ill get a picture tomorro, but f**k me, its under 2 inch in there. no point having this amazing free flowing exhaust with that dump on.
it did the job well, got me out of a grind, but now i can afford it, upgrade time. hopefully ther guy with the 34 dumps on here still has them. time to text him.
Yeah, iirc R34 dumps are stainless, been so long since I took mine off :/
I have been led the believe the R33 GTR dump flows better then the 34, by 2-5ths of F all but still a little better, its the 32 ones you really don't want, all three however have the same or very close to same outlet size :(
i guess we will have a look when they turn up. being stainless at least me an scotty can hack em up and weld on a bigger exit.
its not so much the outlet on the 33 one i have, but the inlet. and the god damn weight, being cast its about 4kg!
i know that, but unfortunately i cant get any more boost out of the stock wheel with out stripping it....
so new steel wheel on the back.... ill weigh the shafts side by side to see what the difference is....
Yeah will be good to see what the difference is.
This is what happens when you run too much on the stock wheel...
^^was found in my cat.
I was running 7 psi when i did that lul....
More powah :woot:
Also can't remember, you putting this on corn syrup?
  • Like 1
Next project car? Liberty?
shhhh. thats for another time. :woot:
lets just say my little family needs more space than a wrx gives you.....
come on 5 oclock..... im off round to visit the e85 yoda with some bourbon a sump and a f**king turbo.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
