exactly what im aiming for... starlet is 1.3 engine also yes?
fabricator reckons itll pull crazy power..... im not so sure. engine is 300k old...
1331cc 321,000km engine.
Also it's my wife's car :)
so this weekend, we finished the cooler piping, and made a custom intake using a rip off hks filter from china!
car runs and runs well, although we have the bov completely disconected from the cooler piping as too stop the boost getting to the engine.
specs.
1275 300km engine
ga15 throttle body and afm
custom manifold
custom cooler piping
ford xr6 turbo intercooler
1 x t28 garrett gtr turbo.
future mods (to support e85)
gtst fuel pump.
cga3 top feed fuel rail, modded with vq25 injectors to fit cg13 intake mani.
exedy hd clutch
jun 3.4kg flywheel. (or 4kg cant rememebr)
hopefully get this done over the next two weekends.... tune is 6th of june. (if the nistune is ready in time)
the little micra that could, rajabdamn.
cant believe you got the fuel rail to work with those bits and pieces, usually they are a PITA to get different things to fit.
Where did you source the clutch and flywheel? did they double the budget of this build?
havent got the fuel rail to fit yet.
yes it will be fidlly, but its been done before, the only issue is clearance.....
i got the clutch and fly in a package with the hks/ohlins/tein suspension setup. and it cost just under a years rego.
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
