WEEKEND UPDATE!
scotty had to remove and weld up my throttle body/afm, where the iacv valve should be. i will get him to barb it in the future so i can remote mount it.
all this was required to fit the euro spec top feed micra fuel rail. (its from the same engine, just a 10 year on updated coilpack version)
we then added various o-rings and shiz (scotty is a genius at this, i wouldnt have known where to start)
370cc neo/stagea injectors installed!
i then spent freaking ages trying to get a 33gtr pump installed in the stock cradle. eventualled managed to get it in there with a slight change in where it picks up from......
tank was drained of dino fuel and replaced with 20 litres of e85.......
i then pulled out my shiny new nistune fitted ecu. installed it, and primed the pump a few times. we found a small leak at the fpr, and just found it wasnt seated properly. scottty bent some welding wire and inserted it, holding the fpr down and leak be gone!
guess what.
it works.
took it for a couple of laps around the estate and it works fine, even getting some boost down very very low, so i have to be careful.
she is ready to be tuned!
apart from one small tiny thing.
the pick up location of the fuel pump no means if i go round a right hand corner with less than half a tank, it stutters hahah!
we filled her up with e85 and i went for another spin. shes fine. will drain the tank at a later date and rotate the pickup.
nistune, added 30% more fuel across the range to allow me to use e85 to get there. the car is running hella rich, but drives fantastic.
really looking forward to friday';s results.
next on the agenda is to finish the swift gti seats install. they are slightly higher up than the micra seats, but this is fine for now. will head over to finish welding the passenger on thursday and pick the car up for the tune.
f**k. yea.
literally the stock ecu with a daughter board attached to allow tuning of factory maps.
sure it doenst have duel maps, and the features of all the other options, but its the cheapest, and thats what matters! haha!
what do you run on the pulsar?!
yeah thats what I thought. good jerb
was just curious as pulsar version of nistune is just a daughterboard. its cheap, easy and effective for what you need for +T. however apparently skyline version is $$$.
(I have powerfc but know heaps of turbo and VVL pulsars on nistune)
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
