Im looking at selling my 1996 Skyline GTS25T Series 2. Selling it because i need to start paying off some bills.
Body and engine is great condition and with genuine low kilometers.
Replaced the brake pads a few months ago and there was still the original nissan hitachi pads in the front and rear!
Dash doesn't have a single crack or marks anywhere, which is very rare. Interior including front and rear seats are in next to perfect condition.
Replaced:
-Falken ZE912 225/40/18s x4 in December 2013
-Font & rear disc brake pads with Bendix pads
-New Genuine Nissan coilpacks x6
-Platinum NGK Spark plugs
-NGK O2 sensor
-Bought a Stock Airbox instead of original pod filter
-Oil changed at 135 thousand with Penrite HPR 5 oil, new filter and fuel filter.
-Dump pipe re plumbed in March by Leonards Mufflers Coffs Harbour,
i could notice a difference in power. Photo of pipe above
-Brand new Century hi performance battery other week.
-Also have sway bar links that are getting replaced next week.
PRICE $12,990 ONO NO SWAPS
Located Coffs Harbour
If you have any questions or would like to make an appointment please call me on 0434906977. Cheers Nick
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
