Mohsen Posted May 2, 2014 Share Posted May 2, 2014 hey guysgetting over this piece of shit.freshly built 26 with GTSS'sstock boost, stock injectors, pump with 12v direct feed and stock ecu.the goal is to get it running nice and mint, in stock format, before i begin adding more fuel, boost etc and reach the final goal.so far.car does not miss on idle.car will miss, splutter, cough etc when given a bit of throttle when cold, wont get above 15kmsonce warm, the car will not miss at all, and will drive normal, although EXTREMELY SLUGGISHi mean, so sluggish the old RB20 went harder than this.it feels like theres a restriction somewhere.its doing my head in,thank you in advance.ps: im seriously considering burrying this car, this car is the root of all evil, this car is the devil Z's R chassis cousin.f**k this car. Link to comment https://www.sau.com.au/forums/topic/442615-rb26-missing-spluttering-sluggish-being-a-flamin-mongrel-help-me-before-i-burn-this/ Share on other sites More sharing options...
zebra Posted May 2, 2014 Share Posted May 2, 2014 Cam timing? Cas? Link to comment https://www.sau.com.au/forums/topic/442615-rb26-missing-spluttering-sluggish-being-a-flamin-mongrel-help-me-before-i-burn-this/#findComment-7271981 Share on other sites More sharing options...
Mohsen Posted May 2, 2014 Author Share Posted May 2, 2014 timings on 20 degrees Link to comment https://www.sau.com.au/forums/topic/442615-rb26-missing-spluttering-sluggish-being-a-flamin-mongrel-help-me-before-i-burn-this/#findComment-7272044 Share on other sites More sharing options...
zebra Posted May 2, 2014 Share Posted May 2, 2014 Cam timing, not ignition timing Link to comment https://www.sau.com.au/forums/topic/442615-rb26-missing-spluttering-sluggish-being-a-flamin-mongrel-help-me-before-i-burn-this/#findComment-7272078 Share on other sites More sharing options...
scotty nm35 Posted May 2, 2014 Share Posted May 2, 2014 Moh, learn to internetz mechanic better. Link to comment https://www.sau.com.au/forums/topic/442615-rb26-missing-spluttering-sluggish-being-a-flamin-mongrel-help-me-before-i-burn-this/#findComment-7272081 Share on other sites More sharing options...
XKLABA Posted May 2, 2014 Share Posted May 2, 2014 Check TPS and AFMs, I'd be more AFMs Link to comment https://www.sau.com.au/forums/topic/442615-rb26-missing-spluttering-sluggish-being-a-flamin-mongrel-help-me-before-i-burn-this/#findComment-7272259 Share on other sites More sharing options...
Mohsen Posted May 3, 2014 Author Share Posted May 3, 2014 Wont be the afms as they were swapped out and cleaned, as well as had the solder mod.tps is possible, cam timing is in stock position.could be a collapsed cat? Link to comment https://www.sau.com.au/forums/topic/442615-rb26-missing-spluttering-sluggish-being-a-flamin-mongrel-help-me-before-i-burn-this/#findComment-7272460 Share on other sites More sharing options...
scotty nm35 Posted May 3, 2014 Share Posted May 3, 2014 It's easy enough to drop the flange and see if it helps, but it would have to be a pretty bad blockage... Rag in the cooler pipe perhaps? Link to comment https://www.sau.com.au/forums/topic/442615-rb26-missing-spluttering-sluggish-being-a-flamin-mongrel-help-me-before-i-burn-this/#findComment-7272465 Share on other sites More sharing options...
Mohsen Posted May 3, 2014 Author Share Posted May 3, 2014 im about to leave work and will have a look when i get home. Link to comment https://www.sau.com.au/forums/topic/442615-rb26-missing-spluttering-sluggish-being-a-flamin-mongrel-help-me-before-i-burn-this/#findComment-7272471 Share on other sites More sharing options...
XKLABA Posted May 3, 2014 Share Posted May 3, 2014 What about a leak between the AFMs and throttle bodies, like a split hose or a hose pulled out of a clamp Link to comment https://www.sau.com.au/forums/topic/442615-rb26-missing-spluttering-sluggish-being-a-flamin-mongrel-help-me-before-i-burn-this/#findComment-7272676 Share on other sites More sharing options...
Piggaz Posted May 3, 2014 Share Posted May 3, 2014 Take to competent tuner, decent ecu, smoke test, get on dyno. Report back. Link to comment https://www.sau.com.au/forums/topic/442615-rb26-missing-spluttering-sluggish-being-a-flamin-mongrel-help-me-before-i-burn-this/#findComment-7272837 Share on other sites More sharing options...
Mohsen Posted May 3, 2014 Author Share Posted May 3, 2014 Will check afm leaks. Piggaz, were trying to get it to run properly on the standard hardware first before I throw in the Ecu etc Link to comment https://www.sau.com.au/forums/topic/442615-rb26-missing-spluttering-sluggish-being-a-flamin-mongrel-help-me-before-i-burn-this/#findComment-7272838 Share on other sites More sharing options...
Dose Pipe Sutututu Posted May 4, 2014 Share Posted May 4, 2014 borrow another CAS, unplug TPS and re-time at 20, plug back TPS, report back Link to comment https://www.sau.com.au/forums/topic/442615-rb26-missing-spluttering-sluggish-being-a-flamin-mongrel-help-me-before-i-burn-this/#findComment-7273114 Share on other sites More sharing options...
SiR_RB Posted May 4, 2014 Share Posted May 4, 2014 Need aftermarket ecu and tune? Link to comment https://www.sau.com.au/forums/topic/442615-rb26-missing-spluttering-sluggish-being-a-flamin-mongrel-help-me-before-i-burn-this/#findComment-7273205 Share on other sites More sharing options...
Mohsen Posted May 4, 2014 Author Share Posted May 4, 2014 wasnt able to get much done, as the week end was pretty busy, and it was raining. borrow another CAS, unplug TPS and re-time at 20, plug back TPS, report back will try this as soon as i can Link to comment https://www.sau.com.au/forums/topic/442615-rb26-missing-spluttering-sluggish-being-a-flamin-mongrel-help-me-before-i-burn-this/#findComment-7273703 Share on other sites More sharing options...
flavzz Posted May 14, 2014 Share Posted May 14, 2014 I had a very similar issue with my 26. Ended up being faulty cas. Get a workshop to plug into your ecu to check. Link to comment https://www.sau.com.au/forums/topic/442615-rb26-missing-spluttering-sluggish-being-a-flamin-mongrel-help-me-before-i-burn-this/#findComment-7283176 Share on other sites More sharing options...
GD51LA Posted May 21, 2014 Share Posted May 21, 2014 Mine had the same issue, just felt like it was being held back, I swapped the igniter, been perfect ever since Link to comment https://www.sau.com.au/forums/topic/442615-rb26-missing-spluttering-sluggish-being-a-flamin-mongrel-help-me-before-i-burn-this/#findComment-7289931 Share on other sites More sharing options...
flavzz Posted May 29, 2014 Share Posted May 29, 2014 (edited) Any luck sorting this out yet mate? Edited May 29, 2014 by flavzz Link to comment https://www.sau.com.au/forums/topic/442615-rb26-missing-spluttering-sluggish-being-a-flamin-mongrel-help-me-before-i-burn-this/#findComment-7297500 Share on other sites More sharing options...
