Well, Im the proud owner of an R32 GTST. Have had the car for a month or two now. but in the last 3 days i have been pulled over twice! and both times i have got a ticket saying im driving a restricted vehicle..
The claim that my car is over the power to weight ratio limit.
Im on my P's, and they claim that while im on my P's i must not be driving a car that is over 125Kw per 1000kg. Now on their little sheet that the have with all the stock car weights and powers it says mine is like 125.4kw per ton... yes. point 4 of a fricken kilowatt.
It was the same bloke that got me both times. one at Knox (im in vic btw) and the other in Ringwood near eastland.
He says if he gets me again i will see him in court.. :D
So what can i do?
Has anyone had this trouble before?
Can i detune my car, dyno it, weigh it and say that im not over? or doesnt it work like that? what could i do? anyone have any idea where i could find out?
Thanks all.
all help is much apreciated.
Thanks again in advance :)
https://www.sau.com.au/forums/topic/44263-what-am-i-sposed-to-do-now-need-help/
Welcome to the world of owning a Skyline :D
It will only get worse. lol.
For example, i have owned about 5 cars before my skyline, one of them being a done up commodore. and i never got a ticket or lost a point, i had been pulled over once or twice for a breath test but nothing else.
I owned my skyline for 2 months, have been defected a few times and now currently have 2 points left on my licence.
gotta love your imports :D
How trust worthy is that site though
what says its right over the police's source of information.
Anyone know if there is a nissan website saying how much it weighs?
I also have the actual handbook thingy. which prolly has the weight in it though its kinda all in japanese and i cant read it.
if anyone can read it could have a quick squiz and tell me what page number it is on..
Cheers.
Should i just go down to the station and show them the information? but like i said. who says that website is right?
hmm
well if that site is right then it puts me shit outta luck
that makes it 125.5 kw to the ton
What can i do about it?
i have only just bought the car. dont want to sell it.
is there anything i can do?
i think it would be worthwhile going to Nissan and finding out the exact specifiactions of your car. If it turns out that you are actually under, then take it to court and prove your innocense (spell?). There is a similar case in the Victoria section, have a read, there was heaps of feedback, i don't know if it helped much though.
I think that the later post August 91 R32's are heavier. 1260 for up to then and 1320 for a type M post Aug 91. May put you out of reach of that ratio. Especially if u find some Nissan documentation to back u up. I hope urs is post aug 91 cos I would love for that to happen :D
http://www.computeroutpost.com.au/imports/...n&model=Skyline
Guys its not current power vs current weight.
it is factory power vs factory weight...
yes it is stupid - you can buy a non turbo GTS and wack a RB26DETT and probably get away with it since the factory specs of a GTS power to weight is ok
It sounds like either vic cops or this cop in particular is out to get P platers in skylines at the moment - think this is the 3rd thread on this i have seen on here about the same thing, similar area in the last couple of weeks.
I'm going to be really harsh here. Why didn't you check the specifications before you bought the car? Your car is too highly powered for P's. The Law is the Law, and Police issue guidebooks are the Law that's enforced.
Selling the car might be a bit over the top, perhaps garage it until you're off your P's? Either that, or risk your licence by driving around without P's up.
That's my opinion. You can't claim ignorance of the Law - it's no excuse.
geez, 125.4 when its supposed to be 125, all i can say is that u have experienced a great deal of bad luck, i mean couldnt the cop let u go without going into such a technicality since its pretty much on the limit. Fair enough if the cop decided to get you for power to weight if he saw u doin something stupid but really cmon...
the best of luck to you...
I recently imported an 89 r32 gtst type M, and the arrival notice states that it weighs 1320kgs. If yours is the same as this then given the factory output of 160kw, wouldn't that make the power to weight ratio 121.21kw per tonne? This is the gross weight though, not dry weight which they may go by. Anyway hope this may help.
yes its factory weight and factory power output at the flywheel, didnt think r32s were not allowed, thought it was r33s and up(or any GTR), i dont think u can detune it as like i said b4, factory weight and factory power, things you can do:
stay out of Knox, its notorious for cops picking on p platers and using the power/weight restriction on them, take off the 'GTST' sticker on the back of the car, run a plumb back bov, dont give any indication its turbo( no turbo timers, visable coolers etc). it will help a bit
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
