Need to sell my two toys to buy one. Just don't have the room and more importantly the time.
1995 R33 GTR with over 370awkw. Car is very neat and tidy and everything has been done right.
Garret Single turbo conversion with top mount 35R. Rebuilt engine top and bottom. All supporting mods and all done properly. Car is easily street drivable and sure surprises on the road.
Brand new 19x10.5 inch ROH 3 piece wheels only done 100km.
$24000
Cameron
0400 841 142
post-23484-13991626528853_thumb.jpgpost-23484-13991626719836_thumb.jpgpost-23484-13991626845008_thumb.jpgpost-23484-13991626980194_thumb.jpgpost-23484-13991627106503_thumb.jpgpost-23484-13991627238356_thumb.jpg
Has a forged bottom end with slightly oversized pistons, Oil restrictor in block etc. fully recon head.
Runs a Nistune with R35 AFM
Walbro intank pump, direct wired to have better pressure. Aftermarket coilpacks with modified loom. 1000cc injectors
Tein Suspension with adjustable arms.
Little bit more info:
ETM Exhaust manifold ceramic coated
50MM external wastegate
GT35R turbo
Screamer pipe
4 inch dump pipe
3.5 straight through exhaust
Braided oil and water lines
Oil cooler with -10 lines
PWR twin core radiator
Adjustable cam gears
Oil restrictors in block
All new gaskets seals etc and throttle bodies re-sealed
Modified custom engine mounts
OS geiken twin plate clutch
New front wheel bearings
Cross drilled and slotted rotors
Adjustable castor rods
Powder coated rockercovers
powder coated catch can
Control arm spacers
Hks fully adjustable suspension
Mate sorry for the average pics, get home in the dark and garage hasn't got the best light for pics. It is very neat with no tips/holes etc. has a series 3 steering wheel as well.
As for boot no accident damage or anything. All paint originalpost-23484-14005879502201_thumb.jpgpost-23484-1400587968495_thumb.jpgpost-23484-14005879816855_thumb.jpgpost-23484-14005879933543_thumb.jpg
  • 3 weeks later...
    • Knowing how slow their other compressors are that connect to the cars battery, you'd want to hope it's one hell of a slow leak!
    • So why can’t the front pipe just be listed as custom make? why does everything have to have a brand name to it? or if you have bought the car like this and have no idea about anything at all or no knowledge what so ever of parts how are you supposed to inform them of what it is you have exactly?
    • Yep, I'd be interested to hear how it works out in the end.
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
