ok guys im only new at this and i dont even know if i am in the right place but here go's.
i have a 1994 r33 rb25det s1 and my check light is on the dash...
the light comes on for a while then goes out for about 5 sec then appears again for a min or so then go's out for a couple sec and so on
i have done some reading and i have learnt how to bridge to loom to do a diagnostic, but the problem is the engine light dose not flash any codes at me when i do this
can anyone tell me why this is and how can i get the codes out of my ecu
this is my first skyline i have owned
any help will be muchly appreciated
https://www.sau.com.au/forums/topic/442696-check-engine-light/
ok maybe you arnt bridging the right pins, turn your ignition on and when you bridge the pins the engine light will turn on, keep it bridged for a few seconds and then release the pins and the engine light will flash your codes at you. The only alternative is to hook it upto a consult program an a laptop using something like datascan, you will need a special cable to do this
What ecu are you running? The consult port will only work with a standard ecu.
As for the port itself, it's called 'Consult' and is pre OBD2. You need to get a special cable and software to use it. Check this out:
http://www.ecutalk.com/interface.aspx
that is a very good point, if you are bridging those exact pins in the picture and nothing is happening you may have an aftermarket ecu, some are a full replacement and some just change the circuit board in the original one, rip the passenger side kick panel off and have a look, if you see apexi or something like that on it then its aftermarket
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
