Afternoon,
I'm buying R34 GTT front calipers sight unseen from Jap Sports Spares in Smithfield. Has anyone had any experience with these guys?
I'm not a SAU regular but I believe one can't slander an organisation. Can someone PM if they've dealt with them? OR give them some love on this thread if they've had positive experiences.
Or if you've got R34 GTT F calipers FS. sell them to me for $250.
Thanking you in advance
Edited by Drogba
https://www.sau.com.au/forums/topic/442714-buying-front-calipers-from-wreckers/
I've spoken to them over the phone; they seem like decent guys.
Where do you live? Are they sending them to you?
Perhaps some kind of inspection & postage scenario could be arranged if you're worried?
You won't know if they are good or otherwise until you fit them, I have had a few sets lately that leak from between the halves, you can't tell till you start bleeding them.
I think you need to assume they might need a kit through them, I usually do it anyway for my own cars. It isn't hard to do.
Do you have a source for the o-ring that seals the 2 halves?
I stripped mine to blast & coat, but re-used everything as the seals & dust boots were perfect. The seal kits don't contain the sandwich o-ring do they?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
