I was not born in the computer generation ,sorry,Thanks Greypearl.
Um.....it's the computer generation we usually have the most trouble with not being able to form readable prose.
The rules for written language are quite simple.
1) Have an idea you need to convey.
2) Put together words to convey that idea. Use just enough words to correctly convey that idea, then put in a full stop. If one sentence won't cover the whole idea, then start again with a new sentence for the next part of the idea.
3) If you have multiple ideas to convey, repeat the above for the next idea and so on.
4) For breaking up major different ideas, press the enter key a couple of times so you get a new paragraph.
Also, numbered lists like I have used above can be convenient ways for people to address individual points you are raising. They can refer to your numbered points. It's great.
  • Like 1
Thanks GTSBOY so simple when you know how
1) Need to know which are best and why BC'S or Bilsteins.
2) Bear In mind that my car will probably never see the track.
3) Cost is a factor,Cheers Greypearl.
Edited by Robert Knight
  • Like 1
If you want some help making a decision go to the top of this page to the "pinned" topics and read " shockabsorbers 101" by SK.
SK has designed suspension set ups for Skylines and Stageas and I have followed his plans for my Stagea :
Bilstein shocks front and rear (but with Tein springs - missed out on the group buy) and heavy duty anti-roll bars.
I also have adjustable castor and camber arms but set fairly conservatively for the street. I ran 3 deg neg camber at the front and 1.5 deg at the back with my slicks which was great on the track but chewed out my street tyres so I toned it down a little to 1.5 deg front and rear. Tyre wear has gone down but my heavy wagon still handles pretty well on the road.
After maximising the caster (we can never have too much caster on an R32/33/34) I would have gone for 1.0 to 1.5 degrees negative camber on the front and 0.75 to 1.25 degrees negative on the rear. R33GTR are predominantly understeerers due to the ATESSA calibration and HICAS programming, so I also find around 2 mm toe out each side, front and rear, to be beneficial.
Having sorted the wheel alignment the choice of dampers is a pretty simple one, I have found Bilstein work well on R32/33/34's due to their sophisticate valving. There's about 300 or so kits utilising Bilsteins in Skylines, Stageas and Silvias running around from the old Group Buy days and the guys seem pretty happy with them. Depending on the budget non adjustable, single adjustable with or without remote canisters or triple adjustable with remote canisters.
For non adjustable I'd suggest Kings springs (Lows NOT SuperLows) as Redranger in their infinite wisdom discontinued all Whiteline springs. The Bilsteins I do have my valving specs and come with additional circlip grooves so the cars ride height can be selected prior to fitting them. For R33GTR's I never go lower than 355 mm on the front and 345 mm on the rear (centre of wheel to guard as usual) as the ride deteriorates and the suspension geometry is not designed to operate at lower than height.
If finite on car height adjustment is desired then Eibach are the best spring choice. They require the addition of what we call "coil over conversion kits" to the Bilsteins.
Always remember that swaybars are by far the best value handling upgrade, road or track. You have my email address if you want to discuss.
Hope that helps
Cheers
Gary
  • Like 1
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
