Hi guys if anyone can shed some light it will be greatly appreciated.
Firstly the car is a r33 gtst rb25det
Mods
Hypergear highflow (r34 op6)
660cc injectors
040 pump
Power fc
3 inch from turbo back
Return flow cooler
Splitfires
The problem:
Basically the car has been in and out of unigroup engineering when it was first put together it made 247kw at 15psi
Had a small manifold leak so they could not push it more since fixing that and going to push more boost through it, it now only makes 220kw at 20psi but the power drops off early around 5000 rpm they suspected a restriction in exhaust or a boost leak as they retard timing to compensate for more boost but the car wont react as in the timing is not changing.
Car is hitting the dyno again tomorrow with another cas just to rule that out but cant seem to pin point the problem.
Sorry again for the essay :P
Thanks michael
  • Like 1
There are two types of OP6 high flow. Most of the recently once made this year has the updated compressor and turbine whiles which is capable of making a lot more power. The older versions usually stops making power towards the 260rwkws mark, which your first dyno run sort of makes more sense.
Getting the most out of the turbocharger, 3 inches metal induction with a good pod is a must, as well as a proper cooler and free flow exhaust.
Because as they add more boost the car creates less power
sorry i'm a bit confused...on WOT they will set timing in the load areas of the map....the ecu won't change the timing unless they are hitting a water temperature threshold. so they up the boost and you aren't getting anymore power...do you have your dyno graph? that could show a bit more. mine made 229kw with a high flow but just made no more power when we added more boost.....(we really tried)
Hmmm...here's my 2 cents.
The curve looks worse than it is due to the scale.
1. There is a big boost drop as revs rise. At 6000 to 6200rpm it is running 15-16psi. That is entirely consistent with the power level achieved. So I'd first be looking at tension on the wastegate spring. If it's adjustable I'd add 2 turns and see the result. It looks like electronic control - is the GAIN set too high?
2. I don't know the turbine/compressor size but I'm pretty sure they're not large enough to warrant a 4000rpm boost threshold. I'd mention to the tuner that they investigate the AFRs around boost threshold (and knowing at least a tiny bit about how SAU tune they'll need to richen it up a bit coming onto boost, preferably for 800rpm before too).
#1 should fix most of your power issue
#2 should fix the drivability - which is AT LEAST as important.
I'm not saying there aren't other issues going on but it doesn't look too bad considering the boost drop.
Other things to check:
1 - Is the VCT set correctly? Is it ON between approximately 1200 and 4800rpm ?
2 - Is it too lean in places? Better to err on the side of rich rather than lean.
Edited by simpletool
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
